SELECT
Subcase Information Entry Used to identify/select subcase-dependent materials and properties.
SELECT = n
SELECT = 33
| Argument | Options | Description |
| n | (Integer > 0) No default |
The SELECT Subcase Information Entry can directly reference the identification number of SELECT continuation line in MAT1, MATT1, MATS1, PBUSH, and PCONT(3) Bulk Data Entries. |
- This option is supported for all analysis types and element types for which the corresponding material and property Bulk Data Entries (MAT1, MATT1, MATS1, PBUSH) are supported.
- SELECT is also supported in conjunction with the AMSES and Lanczos eigensolvers.
- This option, if referencing PCONT, is supported only for implicit nonlinear analysis.
- The following example demonstrates the use of the
SELECT card for subcase-dependent elasto-plastic card.
- Subcase 1 refers to elasto-plastic material pointing to a stress-strain curve based on TABLES1 ID 12.
- Subcase 2 refers to elasto-plastic material pointing to a stress-strain curve based on TABLES1 ID 13.
SUBCASE 1 …. SELECT = 33 SUBCASE 2 … SELECT = 34 . . MATS1,1,2,PLASTIC +,0 +,SELECT,33 +,,12,PLALSTIC +,0 +,SELECT,34 +,,13,PLALSTIC +,0
