SECSET
Bulk Data Entry Defines free boundary degrees-of-freedom for One-Step Superelement Analysis.
| SECSET | SEID | G1 | C | G2 | C | G3 | C |
| SECSET | 11 | 23 | 6 | 8 | 12 | 511 | 33 |
| SEID | Superelement identification number. No default (Integer ≥ 0) | |
| Gi | Grid or Scalar Point identification
                  numbers. Default = Blank (Integer > 0) | |
| Ci | Component numbers. (Integer zero or blank for scalar points, or up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks for grid points. The components refer to the coordinate system referenced by the grid points.) |
- Degrees-of-freedom on SECSET entry are used to define the boundary degrees-of-freedom which are to be free (C-Set).
