PARAM, RBMEIG
Bulk Data Entry Defines the cut-off eigenvalue for determining rigid body modes calculated by AMLS.
| Parameter | Values | Description |
| RBMEIG | <Real> Default = 1.0 Default: The default cutoff eigenvalue (AMSES and AMLS) is 1.0, if this parameter is not present in the deck.  |
                            PARAM, RBMEIG defines the cutoff eigenvalue for determination of rigid body modes calculated by the AMLS and AMSES eigensolvers. |
- PARAM, RBMEIG functions in a similar manner to PARAM, FZERO, which is used in models solved by the Lanczos eigensolver.
 - The default cutoff eigenvalue of 1.0 is equivalent to a natural frequency of 0.16 Hz.
 - For the Lanczos eigensolver, use PARAM, FZERO to set the cutoff frequency for rigid body modes.
