PARAM, PRGPST
Bulk Data Entry Outputs AUTOSPC information to the .out file.
| Parameter | Values | Description |
| PRGPST | < YES, NO, ALL, NONE, <number of DOFs> > | PRGPST
                                controls the printing of AUTOSPC information to
                                the .out file.
- If the total number of AUTOSPC dofs is less than 100, all the AUTOSPC dofs will be printed, regardless of the number of dofs specified. When the total number of AUTOSPC dofs is more than 100 and the printing is limited by default value of 100, you can specify the number of dofs to print more than 100 in .out file.
