| POST |
<-1,
-2, -5,
RENUM, STOP> |
Adding
PARAM, POST to the Bulk
Data section of the input deck will activate the creation of the
.op2 file.
- -1
- Creates the .op2 file with
displacement results output in the analysis system and
PARAM, ITAPE set to
-1.
- -2
displacement results output in the basic coordinate
system and PARAM,
ITAPE set to 0.
The GEOM3, GPDT and GPL data blocks are also included in
the .op2 file when
PARAM, POST,
-2 is used.
- -5
- Writes the stiffness and mass matrices to the
.k.op2 and the
.m.op2 files, respectively, in
addition to creating the .op2 file
with displacement results output in the analysis system
and PARAM, ITAPE
set to -1.
- RENUM
- Uses the original grid numbering when writing out the
.k.op2 and
.m.op2 files. This way, the
numbering is consistent between the OP2 files and the
FEM file.
- STOP
- Stops the job once the matrices are output to
.k.op2 and
.m.op2 files.
