PARAM, MODETRAK
Bulk Data Entry Tracks mode numbers by comparing eigenvectors between iterations.
| Parameter | Values | Description |
| MODETRAK | <-1, 0, 1, YES, NO> |
 Concerning mode tracking, the following symbols are used in the
                                    output format:
- In topology optimization, mode shapes can change greatly due to the reorganization of material within the design domain. For some models, mode tracking may be of limited effectiveness. Also, the values of optimized modes may increase substantially during the optimization process. You are advised to provide a wide range or large number of modes in the EIGRL card to protect against optimized modes being lost.
- This parameter is ignored if a MODTRAK Subcase Information Entry is present in the input.
