PARAM, INREL
Bulk Data Entry Controls the calculation of inertia relief.
| Parameter | Values | Description |
| VALUE | <-2,
                                    -1, or 0> Default = 0, for static subcases Default = -2, for modal frequency response subcases | INREL
                                controls the calculation of inertia relief. The
                                    VALUE parameter can be set equal to
                                    -2, -1, or 0.
| METHOD | Default = Blank (Integer > 0) | The
                                    METHOD parameter is only applicable if the
                                    VALUE parameter is set to
                                    -2. The METHOD parameter references an EIGRL or EIGRA Bulk Data Entry to support inertia relief analysis for models with more than six rigid body modes. Eigenvalue subcases are automatically generated internally to calculate the rigid body modes. Based on these rigid body modes, inertial loads and support points are determined. Refer to Comments 1 through 7. |
- Eigenvalue subcases are automatically created and do not have to be specified in the model.
- The lower bound (V1) of the EIGRL/EIGRA entries should be less than or equal to zero.
- If specified, the upper bound (V2) of the EIGRL/EIGRA entries should be greater than or equal to the value set by PARAM,FZERO.
- If V2 is not defined, ND field on EIGRL/EIGRA should be input.
- ND is recommended to be set greater than the actual number of rigid body modes in the model.
- Support degrees of freedom will be generated internally, so SUPORT entry is not required.
- It is recommended to use PARAM, FZERO to make sure that the intended rigid body modes are being used to perform inertia relief analysis when using the METHOD parameter.
- Inertia relief is supported for nonlinear static analysis. Any nonlinearity (contact, geometry and material) can be included in nonlinear static analysis with inertia relief.
