PARAM, ERPREFDB
Bulk Data Entry Specifies the reference power value used to calculate Equivalent Radiated Power (ERP) in decibels (dB).
| Parameter | Values | Description |
| ERPREFDB | Real > 0.0 Default = 1.0 | The Equivalent Radiated
                                Power (ERP) in decibels can be calculated using
                                the following equation: Where,
 ERP output in dB scale is currently only available in PUNCH format. |
