Bulk Data Entry Defines non-structural mass as the sum of the sets
        listed.
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | NSMADD |
                            SID |
                            S1 |
                            S2 |
                            S3 |
                            S4 |
                            S5 |
                            S6 |
                            S7 |
                            S8 |
                            S9 |
                            S10 |
                            etc. |
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | NSMADD |
                            4 |
                            100 |
                            200 |
                            | Field |
                            Contents |
                            SI Unit Example |
                            | SID |
                            Non-structural mass set
                                identification number. No default (Integer > 0)  |
                            | S# |
                            Identification number of
                                nonstructural mass sets defined via NSM, NSM1, NSML, and NSML1 entries. No default
                                    (Integer > 0, SID ≠
                                    S#)  |
            - Refer to Non-structural Mass in the User Guide
                for more information on the use of this card.
            - Non-structural mass in this format must be
                    selected by the NSM (Subcase Information Entry) Subcase
                    Information selector.
            - No S# may be the
                identification number of a non-structural mass set defined by another
                    NSMADD entry.
            - NSMADD entries take
                precedence over NSM, NSML,
                    NSM1 or NSML1 entries. If both have the
                same SID, only the NSMADD entry will be
                used.
            - The value of the non-structural mass does
                    not change during Topology Optimization.
