MONPNT1
Bulk Data Entry Defines an integrated load monitor point at a point (x,y,z) in a user-defined coordinate system. The integrated loads about this point over the associated loads will be computed and printed to the .monpnt file.
| MONPNT1 | NAME | LABEL | |||||||
| AXES | COMP | CP | X | Y | Z | CD | |||
| MONPNT1 | WING20 | Wing Load | |||||||
| 23 | WING | 1.0 | 20.0 | 15.0 | |||||
| NAME | Character string of up to 8 characters identifying the
                                    monitor point. No default (Character) | |
| LABEL | A character string that identifies and labels the monitor
                                    point. Default = blank (Character, a maximum of 56 characters, fields 3 through 9) | |
| AXES | Component axes to monitor. (Integer > 0, up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks) | |
| COMP | The name of an AECOMP or
                                        AECOMPL entry which defines the set of
                                    grid points over which the monitor point is defined. No default (Character) | |
| CP | The identification number of a coordinate system in which the
                                    input (x,y,z) coordinates are defined. Default = 0 (Integer ≥ 0) | |
| X, Y, Z | The coordinates in the CP coordinate
                                    system about which the loads are to be monitored. Default = 0.0 (Real) | |
| CD | The identification number of a coordinate system in which the
                                    resulting load components are output. Default = The coordinate system specified by the CP field (Integer ≥ 0) |
- The MONPNT1 entry is supported for linear static and static aeroelastic analysis.
- The entry can create either be an aerodynamic or a structural MONPNT1, depending on the data provided in the COMP field. A structural MONPNT1 can have the same name as an aerodynamic MONPNT1, but two structural or two aerodynamic MONPNT1s cannot have the same name.
- The results requested by MONPNT1 entries will be printed to the .monpnt file.
