MBLIN
Bulk Data Entry Defines the parameters for a multibody system linear analysis.
| MBLIN | ID | TYPE | ASCALE | ENGYDST | PID_IN | PID_OUT | NODAMP |
| MBLIN | 99 | EIGEN | 1.0 |
| ID | Unique identification number. (Integer > 0)  |
| TYPE | Linear analysis type.
| ASCALE | Animation scale. Default = 1.0 (Real > 0.0)  |
| ENGYDST | Specifies whether the modal kinetic
                energy distribution is written out to the solver log file and the
                  *_linz.mrf output file.
| PID_IN | Specifies the plant input ID used for
                the B and D state matrices. No default (Integer)  |
| PID_OUT | Specifies the plant output ID used for the C and D state matrices. | |
| NODAMP | Specifies whether the linearization
                solver disables damping from all force elements for the eigenvalue solution.
- For further information, refer to Parameters: Linear Static in the MotionSolve Reference Guide.
 - This card is represented as a load collector in HyperMesh.
