MATHC
Bulk Data Entry This material data defines honeycomb material behavior in Explicit analysis.
The material is used to describe honeycomb and foam with anisotropic behavior. The nonlinear elastoplastic material can be defined separately for all normal and shear behavior for uncompacted configuration, and isotropic material model is considered for a fully compacted model. This material is available for solid elements.
| MATHC | MID | E | NU | RHO | SIGY | VF | |||
| LCA | LCB | LCC | LCAB | LCBC | LCCA | ||||
| EAAU | EBBU | ECCU | GABU | GBCU | GCAU |
| MID | Material
                                    identification number. No default (Integer > 0) | |
| E | Young's Modulus for the compacted honeycomb material No Default (Real > 0) | |
| Nu | Poisson’s ratio for the compacted honeycomb material. No Default (Real > 0) | |
| RHO | Mass Density. No Default (Real > 0) | |
| SIGY | Yield stress for the fully compacted honeycomb material. No Default (Real > 0) | |
| VF | The relative volume at which the honeycomb material is fully
                                        compacted. No Default (0 < Real < 1) | |
| LCA | Identification number of function for sigaa versus volumetric
                                        strain. No Default (Integer > 0) | |
| LCB | Identification number of function for sigbb versus volumetric
| LCC | Identification number of function for sigcc versus volumetric
| LCAB | Identification number of function for sigab versus volumetric
| LCBC | Identification number of function for sigbc versus volumetric
| LCCA | Identification number of function for sigca versus volumetric
| EAAU | Initial Young's Modulus Eaa in the uncompacted configuration. No Default (Real > 0) | |
| EBBU | Initial Young Modulus Ebb in the uncompacted configuration. No Default (Real > 0) | |
| ECCU | Initial Young's Modulus Ecc in the uncompacted configuration. No Default (Real > 0) | |
| GABU | Initial shear modulus Gab in the uncompacted configuration. No Default (Real > 0) | |
| GBCU | Initial shear modulus Gbc in the uncompacted
| GCAU | Initial shear modulus Gca in uncompacted configuration. No Default (Real > 0) |
- Uncompacted Honeycomb Material V > VFThe Behavior before compaction is orthotropic and the stresses are completely uncoupled. The elastic moduli by direction vary from their initial value to the isotropic fully compacted value E at Vf as: With andV is relative volume and VF is the relative volume at which the honeycomb is compacted. For the uncompacted configuration the trial stress components are updated as: Each stress component must not exceed the permissible values given by the stress versus volumetric strain defined by the curve (LCAA, LCBB, … and so on) for each component. Thus,The is defined for each component using LCAA, LCBB, LCCC … (see Figure 1).
- Compacted Honeycomb Material V < VFFor the fully compacted honeycomb material, assume the behavior is isotropic and elastic perfectly plastic. Thus, the stress is updated using Hook Material law. So, the deviatoric stresses are given by: Where the deviatoric strain increment is defined by:The equivalent Von Mises stress of the fully compacted honeycomb material is compared to the SIGY. If the effective stress exceeds the yield stress, the tensor stress is simply scaled back to the yield surface using: WhereThe pressure is updated using the Bulk modulus as: WhereThus, the final Cauchy stress is computed as: Figure 1. Stress versus Volumetric Strain
