IMPERF
Subcase Information Entry Defines the initial geometrical imperfection in nonlinear analysis.
IMPERF = option
| Argument | Options | Description |
| option | <SID> No default  |
- IMPERF Bulk Data Entry will not be used, unless selected in the Subcase Information section.
 - IMPERF should only be selected by a nonlinear subcase, which is not continued from a preceding nonlinear subcase.
