HISOUT
I/O Options and Subcase Information Entry The HISOUT command can be used in the I/O Options section to control the amount of data printed to the .hgdata file.
HISOUT = option
| Argument | Options | Description |
| option | <Integer <
                                    32> Default = 31  |
                            HISOUT
                                value is equal to the sum of the desired options:
 Example: If design variables and all DRESP2 responses are wanted, enter: HISOUT= 9  |
- When a HISOUT command is not present, a value of 31 is assumed.
