GROUND
Bulk Data Entry Defines a ground body out of a list of finite element properties, elements, and grid points.
| GROUND | BID | BODY_NAME | |||||||
| TYPE1 | ID1 | ID2 | ID3 | ID4 | ID5 | ID6 | ID7 | ||
| ID8 | etc | ||||||||
| TYPE2 | ID1 | ID2 | etc | ||||||
| TYPE# | etc | ||||||||
| etc | |||||||||
Example 1
| GROUND | 3 | SUPPORTING_BEAM | |||||||
| PSHELL | 23 | 21 | |||||||
| PBEAM | 9 | 59 | 48 | ||||||
| CONM2 | 2345 | ||||||||
| GRID | 400 | 401 | 402 | ||||||
Example 2
| GROUND | 4 | ANCHOR | |||||||
| PBAR | 10 | 11 | 13 | 15 | 22 | 99 | 88 | ||
| 44 | |||||||||
| BID | Unique body identification number. No default (Integer > 0)  |
| BODY_NAME | Unique body name for this
                  PRBODY. Default = OUTFILE_body_<BID> (Character string)  |
| TYPE# | Flag indicating that the following list
                of IDs refer to entities of this type. All property definitions;
                  CELAS2, CONM2, PLTOEL,
                  RBE2, RBE3, RBAR,
                  RROD, and GRID are valid types for this
                  field. No default (PBAR, PBARL, PBEAM, PBEAML, PBUSH, PCOMP, PDAMP, PELAS, PGAP, PROD, PSHEAR, PSHELL, PSOLID, PVISC, PWELD, CELAS2, CONM2, PLOTEL, RBE2, RBE3, RBAR, RROD, or GRID)  |
| ID# | Identification numbers of entities of
                the preceding TYPE flag. No default (Integer > 0)  |
- Any number of property definitions; CELAS2, CONM2, PLOTEL, RBAR, RBE2, RBE3, or RROD elements or grid points can be given.
 - At least one property definition, element, or grid point must be given.
 - A property definition, CELAS2, CONM2, PLOTEL, RBE2, REB3, RBAR, or RROD element or grid point can only belong to one ground or rigid or flexible body.
 - The grid ID provided in the ground card is considered grounded.
 - This card is represented as a group in HyperMesh.
