GENEL
Bulk Data Entry Defines the stiffness, flexibility, mass, viscous damping, or structural damping of a general element connected to an arbitrary number of grids.
Format (Stiffness Matrix)
| GENEL | EID | GI1 | CI1 | GI2 | CI2 | GI3 | CI3 | ||
| GI4 | CI4 | GI5 | CI5 | etc. | |||||
| UD | GD1 | CD1 | GD2 | CD2 | GD3 | CD3 | |||
| GD4 | CD4 | GD5 | CD5 | etc. | |||||
| K or Z | KZ11 | KZ12 | KZ13 | etc. | KZ21 | KZ22 | etc. | ||
| KZ31 | KZ32 | etc. | |||||||
| S | S11 | S12 | S13 | etc. | S21 | S22 | etc. | ||
| S31 | S32 | etc. |
Format (Mass Matrix)
| M | M11 | M21 | M31 | etc. | M22 | M32 | etc | ||
| M33 | M43 | etc. |
Format (Viscous Damping Matrix)
| B | B11 | B21 | B31 | etc. | B22 | B32 | etc | ||
| B33 | B43 | etc. |
Format (Structural Damping Matrix)
| K4 | K411 | K421 | K431 | etc. | K422 | K432 | etc | ||
| K433 | K443 | etc. |
Example 1
| GENEL | 537 | 1001 | 1 | 1001 | 2 | 1001 | 3 | ||
| 1002 | 1 | 1002 | 2 | 1002 | 3 | ||||
| K | 5757. | -816.6 | -43.1 | -5757. | 816.6 | 43.1 | 35479.3 | ||
| -1151. | 816.6 | -35479.3 | 1151. | 6538.6 | 43.1 | 1151. | -6538.6 | ||
| 5757. | -816.6 | -43.1 | 35479.3 | -1151. | 6538.6 |
Example 2
| GENEL | 4001 | 1073 | 1 | 1073 | 2 | 1073 | 3 | ||
| 1073 | 4 | 1073 | 5 | 1073 | 6 | ||||
| UD | 1074 | 1 | 1074 | 2 | 1074 | 3 | |||
| 1074 | 4 | 1074 | 5 | 1074 | 6 | ||||
| Z | .592-6 | .39-6 | .592-6 | ||||||
| -.39-6 | .1-9 | ||||||||
| .319-6 | .319-6 | .1-9 |
Example 3
| GENEL | 435 | 11 | 1 | 23 | 4 | 72 | 0 | ||
| 17 | 2 | ||||||||
| S | 1.7 | 2.3 | 3.6 | 4.4 | 5.2 | 6.8 | 7.1 | ||
| 8.9 | |||||||||
| K | .1 | .2 | .3 | .4 | .5 | .6 | .7 | ||
| .8 | |||||||||
| UD | 12 | 2 | 47 | 0 |
Example 4
| 17 | 2 | ||||||||
| M | 2.1 | 3.2 | 1.8 | 2.2 | 0.9 | 1.2 | 3.1 | ||
| 0.89 |
| EID | Unique element
                                identification number. No default (Integer > 0) | |
| GIi/CIi | Grid (or scalar point) and
                                component identification numbers ordered according to stiffness or
                                flexibility values specified after KZmn. For
                                scalar points, CIi is zero. No default (GIi is integer > 0 and CIi is integer > 0) | |
| UD | Flag indicating that the
                                subsequent fields and continuation entries contain values for
                                    GDj/CDj until
                                    K, Z, or
                                    S is specified in field 2 or it is the end of
                                the entry. No default (Character) | |
| GDj/CDj | Grid (or scalar point) and
                                component identification numbers ordered according to the columns in
                                the S matrix. No default (GDj is integer > 0 and CDj is integer ≥ 0) | |
| K or Z | Flag indicating that the
                                next fields and continuation entries contain stiffness values until
                                    UD or S is specified in
                                field 2 or it is the end of the entry. No default (Character) | |
| KZmn | Stiffness or flexibility
                                matrix for degrees-of-freedom in
                                    GIi/CIi where
                                    m is the row number and n
                                is the column number. Only the lower triangular terms in the matrix
                                need to be specified. Zero values must be specified as blank or
                                    0.0. Default = 0.0 (Real) | |
| S | Flag indicating that the
                                subsequent fields and continuation entries contain values for the
                                    S matrix. No default (Character) | |
| Sij | S
                                matrix values where I corresponds to
                                    GIi/CIi list and
                                    j corresponds to
                                    GDj/CDj list until
                                    K, Z, or
                                    UD is specified in field 2 or it is the end
                                of the entry. All the terms in the matrix must be specified and zero
                                values must be specified as blank or 0.0. Default = 0.0 (Real) | |
| Mass Matrix: 8 9 10 | ||
                                component identification numbers ordered according to mass values
                                specified in Mmn. No default (GIi is Integer > 0 and CIi is Integer ≥ 0) | |
| M | Flag indicating that the
                                next fields and continuation entries contain mass values until it is
| Mmn | Mass matrix for
                                degrees-of-freedom in GIi/CIi
                                where “m” is the row number and
                                    “n” is the column number. Only the lower
                                triangular terms in the matrix need to be specified. Zero values
| Viscous Damping Matrix: 8 9 10 | ||
                                component identification numbers ordered according to viscous
                                damping values specified in Bmn. No default (GIi is Integer > 0 and CIi is Integer ≥ 0) | |
| B | Flag indicating that the
                                next fields and continuation entries contain viscous damping values
                                until it is the end of the entry. No default (Character) | |
| Bmn | Viscous damping matrix for
| Structural Damping Matrix: 8 9 10 | ||
                                component identification numbers ordered according to structural
                                damping values specified in K4mn. No default (GIi is Integer > 0 and CIi is Integer ≥ 0) | |
| K4 | Flag indicating that the
                                next fields and continuation entries contain structural damping
                                values until it is the end of the entry. No default (Character) | |
| K4mn | Structural damping matrix
                                    GIi/CIi where
- GIi/CIi and KZmn are required inputs. Either K or Z must be specified, but not both.
- UD, K, Z, and S, may be specified in any order as demonstrated in the third example.
- UD and
                    S are optional inputs. S defines the
                motion between the GIi/CIi and
                    GDj/CDj degrees-of-freedom according
                    to:But if S is specified, then GDj/CDj must also be specified. If S is not specified, then GDj/CDj may contain six and only six degrees-of- freedom and they cannot refer to SPOINTs.
- If
                only K or Z is input without
                    UD, then it is recommended that the resulting stiffness
                represents the unsupported element, containing all of the rigid body modes. If not,
                the UD option allows for the reintroduction of the rigid body
                modes with S which is provided by you or computed internally. - If
                                 and UD are specified,
                            the program will form the complete stiffness as defined
                                by:Where, the matrix is formed from the KZmn values and the S matrix is formed from the Sij values or computed automatically.
- If Z and UD are specified, then the
                            program will form the complete stiffness as defined by: Where, the Z matrix is formed from the KZmn values and the S matrix is formed from the Sij values or computed automatically. Z must be nonsingular.
- If
                                by:
- PARAM, CK3 may be used to scale the stiffness produced by all GENEL elements.
- All lower triangular values in K and Z and all values in S have to be accounted for in the input. Zero values may be specified as 0.0 or be left blank, however if all entries in any continuation line are zero, then at least one visible character must appear on this line (it can be 0.0 in any field or the plus sign (+) in the first column) because blank lines are treated as comment. Unused fields (after the last matrix entry) must be blank.
- General elements are ignored in heat transfer analysis.
- GIi/CIi and Mmn (or Bmn/K4mn) are required inputs.
- “UD” and “S” should not be defined along with Mass, Viscous Damping, or Structural Damping matrices.
- Only lower triangular terms in the matrix should be input.
