FREQ5
Bulk Data Entry Defines a set of frequencies for the modal method of frequency response analysis by specification of a frequency range and fractions of the natural frequencies within that range.
| FREQ5 | SID | F1 | F2 | FR1 | FR2 | FR3 | FR4 | FR5 | |
| FR6 | FR7 | etc. |
| FREQ5 | 6 | 20.0 | 200.0 | 1.0 | 0.6 | 0.8 | 0.9 | 0.95 | |
| 1.05 | 1.1 | 1.2 |
| SID | Set identification
                                        number. No default (Integer > 0)  |
| F1 | Lower bound of modal
                                    frequency range in cycles per unit time. Default = 0.0 (Real ≥ 0.0)  |
| F2 | Upper bound of
                                    frequency range in cycles per unit time. Default = 1.0E20 (Real > 0.0, F2 > F1)  |
| FRi | Fractions of the
                                    natural frequencies in the range F1 to
                                        F2. No default (Real > 0.0)  |
- FREQ5 applies only to the modal method frequency response analysis.
 - FREQ5 entries must be selected in the Subcase Information section with FREQUENCY = SID.
 - The frequencies defined by this entry are
                    given by fi =
                        FRi *
Where, are the modal frequencies in the range F1 through F2.
If this computation results in excitation frequencies less than F1 and greater than F2, those computed excitation frequencies are ignored.
 - Excitation frequencies may be based on natural frequencies that are not within the range (F1 and F2) as long as the calculated excitation frequencies are within the range.
 - Since the forcing frequencies are near structural resonances, it is important that some amount of damping be specified.
 - All FREQi entries with
                    the same set identification numbers will be used. Duplicate frequencies will be
                    ignored.
                         and
                         are considered duplicated if:Where,
- DFREQ
 - User parameter with a default of 10-5 *
 - The maximum and minimum excitation frequencies of the combined FREQi entries
 - In design optimization, the excitation frequencies are derived from the modal frequencies computed at each design iteration.
 - In modal analysis, solutions for modal degrees-of-freedom from rigid body modes at zero excitation frequencies may be discarded. Solutions for non-zero modes are retained.
 - This card is represented as a load collector in HyperMesh.
