Pattern grouping is a feature where you can define a single part of the domain that
should be designed in a certain pattern.pattern grouping - free-size
optimization.
Planar Symmetry
It is often desirable to produce a design that has symmetry. Unfortunately, even if
the design space and boundary conditions are symmetric, conventional free-size
optimization methods do not guarantee a perfectly symmetric design.
By using symmetry constraints in free-size optimization, symmetric designs can be
attained regardless of the initial mesh, boundary conditions, or loads. Symmetry can
be enforced across one plane, two orthogonal planes, or three orthogonal planes. A
symmetric mesh is not necessary, as OptiStruct will
create variables that are very close to identical across the plane(s) of
symmetry.
To define symmetry across one plane, it is necessary to provide an anchor grid and a
reference grid. The first vector runs from the anchor grid to the reference grid.
The plane of symmetry is normal to that vector and passes through the anchor
grid.Figure 1. Symmetry Across One Plane
To define symmetry across two planes, a second reference grid needs to be provided.
The second vector runs from the anchor grid to the projection of the second
reference grid onto the first plane of symmetry. The second plane of symmetry is
normal to that vector and passes through the anchor grid.Figure 2. Symmetry Across Two Planes
To define symmetry across three planes, no additional information is required, other
than to indicate that a third plane of symmetry is to be used. The third plane of
symmetry is perpendicular to the first two planes of symmetry, and also passes
through the anchor grid.Figure 3. Symmetry Across Three Planes
Uniform Element Thickness
Pattern grouping also provides the possibility to request a uniform element thickness throughout selected components.
This pattern group ensures that all elements of selected components maintain the same element thickness with respect to one another.
Cyclical Symmetry
Cyclical symmetry can also be defined through the use of pattern grouping.
With cyclical pattern grouping, the design is repeated about a central axis a number
of times determined by you. Furthermore, the cyclical repetitions can be symmetric
within themselves. If that option is selected, OptiStruct will force each wedge to be symmetric about its centerline.
To define cyclical symmetry, it is necessary to provide an anchor grid and a
reference grid. The axis of symmetry runs from the anchor grid to the reference
grid. It is also necessary to specify the number of cycles; the repetition angle
will be automatically computed.Figure 4. Cyclical Symmetry
To add planar symmetry within each wedge, a second reference grid needs to be
provided. The plane of symmetry is determined by the anchor grid and the two
reference grids.Figure 5. Planar Symmetry
Linear and Planar Pattern Grouping (TYP=20 and TYP=21)
Linear pattern grouping requires that the anchor point and first point be defined. A
vector from the anchor point to the first point defines the direction in which the
thickness is set to be constant. Linear pattern grouping is typically designed to
handle models with minimal or no curvature in the specified vector direction (which
is typically orthogonal to the rolling direction in rolling applications). For
models with low curvature in the vector direction, appropriate projections to the
surface are used to determine the direction on the surface. For models with high
curvature in the vector direction, depending on the direction of the specified
vector, the direction may become orthogonal to the surface whereby the pattern
grouping direction cannot be determined. In such cases, Planar Pattern Grouping
(TYP=21) is recommended.Figure 6. Planar Pattern Grouping
Planar pattern grouping requires that the anchor point and first point be defined. A
vector from the anchor point to the first point is defined and thickness of the
model in the various orthogonal planes to this vector is set to be constant. Planar
pattern grouping is designed to handle models with high curvature in the orthogonal
planes of the defined vector, and with minimal or no curvature in the direction of
the defined vector. The vector defined in planar pattern grouping should typically
lie in the rolling direction in rolling applications. This feature can handle large
curvature in the slicing plane orthogonal to the defined vector. Planar pattern
grouping cannot be used if large curvature exists in the rolling direction.Figure 7.
