.flt file
An OptiStruct ASCII format results file containing the summary of aeroelastic flutter analysis.
File Creation
This file is created by default for aeroelastic flutter analysis.
File Contents
A typical .flt file containing the flutter summary
                is:
             Subcase =        1
                                                          FLUTTER  SUMMARY
                          CONFIGURATION = AEROSG2D     XY-SYMMETRY = ASYMMETRIC     XZ-SYMMETRY =  SYMMETRIC
       POINT =        1 MACH NUMBER =  0.9000    DENSITY RATIO =  1.0000E-01     METHOD = K
        KFREQ            1./KFREQ         VELOCITY            DAMPING         FREQUENCY            COMPLEX   EIGENVALUE
        0.0010       1.0000000E+03     UNSTABL-SYSTEM    UNSTABL-SYSTEM    UNSTABL-SYSTEM    4.3931949E+04     2.0325712E+02
        0.0010       1.0000000E+03     STABLE-SYSTEM-    STABLE-SYSTEM-    STABLE-SYSTEM-    2.0193361E+04    -1.1860746E+02
        0.0010       1.0000000E+03     STABLE-SYSTEM-    STABLE-SYSTEM-    STABLE-SYSTEM-    3.0546665E+05    -7.2971381E+02
 *** USER INFORMATION MESSAGE
THE K OR KE METHOD OF FLUTTER ANALYSIS HAS FOUND A ROOT THAT HAS NO PHYSICAL INTERPRETATION.
        Subcase =        1
                                                          FLUTTER  SUMMARY
       POINT =        2 MACH NUMBER =  0.9000    DENSITY RATIO =  1.0000E-01     METHOD = K
        0.1800       5.5555556E+00     4.1282076E+01    -5.0589764E-02     4.2403886E+00    -1.6998593E+03    -8.5995482E+01
        0.1800       5.5555556E+00     1.7230486E+02    -8.9340353E-02     1.7698711E+01    -2.9453872E+04    -2.6314194E+03
        0.1800       5.5555556E+00     4.4410222E+02    -5.0649869E-01     4.5617037E+01    -1.5696010E+05    -7.9500083E+04The data available in the .flt file is:
        - Result Entity
 - Details
 - Subcase
 - Number of the subcase.
 - CONFIGURATION
 - Identifies the databases associated with the aerodynamics. Currently, the aerodynamic model is computed from the Bulk Data Entries of the analysis deck and the corresponding database is denoted by AEROSG2D.
 - XY-SYMMETRY and XY-SYMMETRY
 - Symmetry flags from the AESYMXY and AESYMXZ entries.
 - POINT
 - Point of the flutter analysis.
 - MACH NUMBER
 - Mach number specified in FLFACT entry.
 - DENSITY RATIO
 - Density ratio specified in FLFACT entry.
 - METHOD
 - Method of flutter analysis.
 - KFREQ
 - Reduced frequency specified in the FLFACT entry.
 - Velocity
 - Velocities calculated from the complex eigenvalues.
 - Damping
 - Damping calculated from the complex eigenvalues.
 - Complex eigenvalue
 - Calculated complex eigenvalues in the flutter analysis.
- For more details on flutter analysis and output, refer to Dynamic Aeroelastic Analysis in the User Guide.
