FATSEQ
Subcase Information Entry The FATSEQ command can be used to indicate that a subcase is a fatigue analysis subcase and to select a FATSEQ Bulk Data Entry that will define the loading sequence for the Fatigue Analysis.
FATSEQ = option
| Argument | Options | Description |
| option | <SID> No default  |
- This command may not appear above the first subcase.
