.effmass file
The .effmass file is an OptiStruct ASCII format results file.
File Creation
This file is created when MEFFMASS with TYPE = COMP or PROP or SET = ID is used.
File Contents
This file contains the modal participation factor, modal participation factor ratio, modal effective mass, and modal effective mass fraction values.
- When TYPE of COMP is used, the output is
                    printed to this file based on HyperMesh
                    components.Component <HyperMesh_component_name> MODAL PARTICIPATION FACTORS FOR SUBCASE <subcase_ID> . . . MODAL PARTICIPATION FACTORS RATIOS FOR SUBCASE <subcase_ID> . . . MODAL EFFECTIVE MASS FOR SUBCASE <subcase_ID> . . . MODAL EFFECTIVE MASS FRACTION FOR SUBCASE <subcase_ID> . . .
- When TYPE of PROP is used, the output is
                    printed to this file based on property
                    ID.Property <property_ID> MODAL PARTICIPATION FACTORS FOR SUBCASE <subcase_ID> . . . MODAL PARTICIPATION FACTORS RATIOS FOR SUBCASE <subcase_ID> . . . MODAL EFFECTIVE MASS FOR SUBCASE <subcase_ID> . . . MODAL EFFECTIVE MASS FRACTION FOR SUBCASE <subcase_ID> . . .
- When TYPE of SET = ID is
                    used along with a suitable MEFFSET definition, the output is
                    printed to this file based on the HyperMesh set
                    name.Element Set <HyperMesh_set_name> MODAL PARTICIPATION FACTORS FOR SUBCASE <subcase_ID> . . . MODAL PARTICIPATION FACTORS RATIOS FOR SUBCASE <subcase_ID> . . . MODAL EFFECTIVE MASS FOR SUBCASE <subcase_ID> . . . MODAL EFFECTIVE MASS FRACTION FOR SUBCASE <subcase_ID> . . .
