EDRAWB
Bulk Data Entry Defines location and restraining force per unit length for a draw bead in a one-step stamping simulation.
| EDRAWB | EID | S1 | T2 | S2 | T2 | DFORCE | DSID |
| EDRAWB | 13 | -1.0 | 1.0 | 1.0 | -1.0 | 100.0 | 2 |
| EID | Element identification number. No default (Integer > 0)  |
| S1, T1 | Parametric entry points for the line. No default (Real; | S1, T1 | ≤ 1.0)  |
| S2, T2 | Parametric exit points for the line. No default (Real; | S2, T2 | ≤ 1.0)  |
| DFORCE | Draw
                                                  bead restraining force per unit length. No default (Real)  |
| DSID | Draw
                                                  bead set identifier for retrieving the input file
                                                  back to HyperForm. Not
                                                  used by the solver. No default (Integer > 0)  |
- This entry is only valid with an @ HyperForm statement in the first line of the input file.
