DPHASE
Bulk Data Entry Defines the phase lead term in the equation of the dynamic loading function. DPHASE is used in conjunction with RLOAD1 and RLOAD2 entries.
| DPHASE | SID | P | C | TH1 | P | C | TH2 |
| DPHASE | 5 | 33 | 1 | 3.4 | 34 | 1 | 3.4 |
| SID | Identification
                                    number. No default (Integer > 0) | |
| P, P | Grid or scalar point
                                identification number. No default (Integer > 0) | |
| C, C | Component number. No default (Integers 1 through 6, or 0 for scalar points) | |
| TH1, TH2 | Phase lead
         in degrees. No default (Real) |
- One or two dynamic load phase lead terms may be defined on a single entry.
- SID must be referenced on a RLOAD1 or RLOAD2 entry for the formula that define how the phase lead is used.
- A DAREA entry should be used to define a load at P# and C#.
- When the SPSYNTAX setting on the SYSSETTING I/O Option is set to CHECK (default) or STRICT, it is required for grid/component pairs (G#/C#) that the component be 0 or blank when the grid reference is a scalar point (SPOINT), and that the component be ≥ 1 when the grid reference is a structural grid point (GRID). When SPSYNTAX is set to MIXED, it is allowed for grid/component pairs (G#/C#) that the grid reference be either a scalar point (SPOINT) or a structural grid point (GRID) when the component is 0, 1 or blank; interpreting all of these as 0 for scalar points and as 1 for structural grids. When the component is greater than 1, the grid reference must always be a structural grid (GRID).
- This card is represented as a constraint load in HyperMesh.
