Bulk Data Entry Specifies the number of segments, in a cyclic symmetry analysis.
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(9)
(10)
CYSYM
NSEG
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(9)
(10)
CYSYM
12
Field
Contents
SI Unit Example
NSEG
Number of segments.
No default (Integer > 1)
CYSYM and CYJOIN Bulk Data Entries are required in cyclic
symmetry analysis.
Supported analysis types include
linear static (STATIC), normal mode (MODES) and implicit nonlinear (NLSTAT
& NL-DTRAN) analyses, and prestressed analyses are supported with
STATSUB(PRELOAD).
For normal mode analysis, currently only Lanczos
(EIGRL) and Lapack-based dense
(EIGRD) solvers are supported. Note that field 4,
ND, on both cards defines the number of roots desired
for each harmonic in a cyclic symmetry modal analysis.
Linear static and normal mode cyclic symmetry analyses can simulate
non-cyclic symmetric behaviors (deformation and mode shapes, respectively),
and this sets it apart from analyses which use periodic boundary conditions.
Non-cyclic symmetric behaviors are not supported for prestressing subcases
in prestressed analysis due to theoretical restrictions. However, the
subsequent prestressed subcase can have non-cyclic symmetry. Nonlinear
analyses do not support non-cyclic symmetric behaviors.
SPC and MPC references in the
subcase section are required to be consistent for all subcases in cyclic
symmetry analysis.
The modeled segment is defined as
the basic segment with index of 1. The rest of the segments are numbered
following the right-hand screw rule, where the thumb points in the positive
direction of the axis and the segment indices are defined sequentially in
the counter clockwise order. Figure 1Figure 1. Illustration of the numbering of segment
indices
