CQPSTN
Bulk Data Entry Defines a plane strain quadrilateral element in x-z or x-y plane.
| CQPSTN | EID | PID | G1 | G2 | G3 | G4 | G5 | G6 | |
| G7 | G8 | THETA |
| CQPSTN | 111 | 2 | 31 | 74 | 75 | 32 | 51 | 52 | |
| 53 | 85 | 15.0 |
| EID | Unique element
                                    identification number. No default (Integer > 0)  |
| PID | A
                                        PPLANE entry identification
                                        number. Default = EID (Integer > 0)  |
| G1, G2, G3, G4 | Identification numbers
                                    of connected corner grid points.  These fields are mandatory. No default (Integers > 0, all unique)  |
| G5, G6, G7, G8 | Identification numbers
                                    of connected edge grid points. Default = blank (Integers > 0 or blank)  |
| THETA | Material orientation angle in
                    degrees. Default = 0.0 (Real)  |
- Element identification numbers must be unique with respect to all other element identification numbers.
 - The Grid ordering of
                            G1 through G8 are defined as:
Figure 1. CQPSTN Definition
 - The continuation line is optional.
 - If the PPLANE entry referenced in field 3 references a MAT3 entry, material properties and stresses are always given in the xm-zm coordinate system shown in Figure 1.
 - Plane strain analysis defined in x-y plane is supported, that is, the axis labels of “z” above can be replaced by “y”.
 - A concentrated load (for example,
                        a load specified by a FORCE entry) at a grid
                            Gi of this element is defined to distribute along the
                        thickness, T, of the element. For example, in order to
                        apply a load of 200 N/m to a node Gi with the element
                        thickness being 5.0m, the amount to be specified on the load entry should
                            be:
The default thickness of 1.0 is used, if T is not specified on the PPLANE entry.
 - Plane strain elements are supported in linear analysis, small and large displacement nonlinear static analyses. They are currently not supported for large displacement inertia relief analysis.
