Output from Contact Analysis
The CONTF I/O Options and Subcase Information Entry can be used to request contact results output for all nonlinear analysis subcases or individual nonlinear analysis subcases, respectively.
The NLOUT entry can be used to request incremental output from a Nonlinear Analysis. Additionally, if an NLOUT entry is specified in the model (and referenced in a subcase), then OptiStruct outputs, by default, for large displacement nonlinear analysis, the history of strain energy and contact stabilization energy to data files which can be plotted with HyperGraph. The HyperGraph main file is entitled filename_nlm.mvw and the HyperGraph data files (in ASCII format) are entitled filename_e.nlm.
Contact Shear Utilization Output
Contact shear utilization factor and shear magnitude output is available via the CONTF output request. Shear magnitude is the summation of grid shear force.
Shear Utilization factor is given by:
U = G r i d   s h e a r   f o r c e F r i c t i o n   C o e f f i c i e n t G r i d   n o r m a l   F o r c e = S h e a r   m a g n i t u d e μ F n MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyvaiabg2 da9maadmaabaWaaSaaaeaadaWcaaqaamaaqaeabaGaam4raiaadkha caWGPbGaamizaiaabccacaWGZbGaamiAaiaadwgacaWGHbGaamOCai aabccacaWGMbGaam4BaiaadkhacaWGJbGaamyzaaWcbeqab0Gaeyye IuoaaOqaaiaadAeacaWGYbGaamyAaiaadogacaWG0bGaamyAaiaad+ gacaWGUbGaaeiiaiaadoeacaWGVbGaamyzaiaadAgacaWGMbGaamyA aiaadogacaWGPbGaamyzaiaad6gacaWG0baaaaqaamaaqaeabaGaam 4raiaadkhacaWGPbGaamizaiaabccacaWGUbGaam4BaiaadkhacaWG TbGaamyyaiaadYgacaqGGaGaamOraiaad+gacaWGYbGaam4yaiaadw gaaSqabeqaniabggHiLdaaaaGccaGLBbGaayzxaaGaeyypa0ZaaSaa aeaadaWcaaqaaiaadofacaWGObGaamyzaiaadggacaWGYbGaaeiiai aad2gacaWGHbGaam4zaiaad6gacaWGPbGaamiDaiaadwhacaWGKbGa amyzaaqaaiabeY7aTbaaaeaadaaeabqaaiaadAeadaWgaaWcbaGaam OBaaqabaaabeqab0GaeyyeIuoaaaaaaa@81EC@
Shear utilization factor (U) is a quantitative measure for determining the load increment at which sliding has occurred (if any). When the utilization factor gets closer to one, sliding occurs.
Currently supported output formats:
Result Type
It is available only in H3D and OPTI formats. In H3D format, it is output on each node. In OPTI format, it is output for each contact interface.
Shear magnitude
It is output for each contact interface and is available only in OPTI format.
