CMASS1
Bulk Data Entry Defines a scalar mass element.
| CMASS1 | EID | PID | G1 | C | G2 | C |
| CMASS1 | 45 | 4 | 653 | 2 |
| EID | Unique element
                                identification number. No default (Integer > 0) | |
| PID | A PMASS property identification number.
 Default = EID (Integer > 0 or <String>) | |
| G1, G2 | Geometric grid point or
                                scalar point identification number. Default = 0 (Integer ≥ 0) | |
| C, C | Component number in the
                                displacement coordinate system specified by the
                                    CD entry of the GRID
                                    data. No default (0 ≤ Integer ≤ 6) |
- Zero or blank may be used to indicate a grounded terminal G1 or G2 with a corresponding blank or zero C or C. A grounded terminal is a point whose displacement is constrained to zero.
- Scalar points may be used for G1 and/or G2, (with a corresponding C and/or C of zero or blank). If only scalar points and/or grounded terminals are involved, it is more efficient to use the CMASS3 entry.
- The two connection points (G1, C) and (G2, C) must not be coincident. Except in unusual circumstances, one of them will be a grounded terminal with blank entries for Gi and Ci.
- A scalar point specified on this entry does not need to be defined on a SPOINT Bulk Data Entry. When the SPSYNTAX setting on the SYSSETTING I/O Options Entry is set to CHECK (default) or STRICT, it is required for grid/component pairs (G#/C#) that the component be 0 or blank when the grid reference is a scalar point (SPOINT), and that the component be > 1 when the grid reference is a structural grid point (GRID). When SPSYNTAX is set to MIXED, it is allowed for grid/component pairs (G#/C#) that the grid reference be either a scalar point (SPOINT) or a structural grid point (GRID) when the component is 0, 1 or blank; interpreting all of these as 0 for scalar points and as 1 for structural grids. When the component is greater than 1, the grid reference must always be a structural grid (GRID).
- Scalar mass elements are ignored in heat transfer analysis.
- String based labels allow for easier visual identification of properties, when being referenced by the elements cards. For more details, refer to String Label Based Input File in the Bulk Data Input File.
- This card is represented as a spring or mass element in HyperMesh.
