CELAS4F
Bulk Data Entry Defines a scalar spring element that is connected only to scalar points without reference to a property entry. The corresponding properties on this entry are not affected by translational and rotational stiffness limits specified using PARAM,ELASSTIF.
| CELAS4F | EID | K | S1 | S2 | GE | S |
| CELAS4F | 42 | 6.2-3 | 2 |
| EID | Unique element
                                identification number. No default (Integer > 0) | |
| K | Stiffness of the scalar
                                    spring. No default (Real) | |
| S1, S2 | Scalar point
                                identification numbers. S1 or S2, but not both, may be blank or zero indicating a constrained coordinate. Default = 0 (Integer ≥ 0; S1 ≠ S2) | |
| GE | Damping
                                        coefficient. GE is ignored in transient analysis, if PARAM, W4 is not specified. Default = 0.0 (Real) | |
| S | Stress
                                    coefficient. Default = 0.0 (Real) |
- This single entry completely defines the element since no material or geometric properties are required.
- Only one scalar spring element may be defined on a single entry.
- A scalar point specified on this entry does not need to be defined on a SPOINT Bulk Data Entry.
- The element force of a spring is
                    calculated from the equation: Where,
- Stiffness coefficient for the scalar element.
- Displacement of the first degree-of-freedom listed on the CELAS4 entry
 Element stresses are calculated from the equation: Where, is the stress coefficient as defined above.
- This card is represented as a spring or mass element in HyperMesh.
