Material Failure Criterion
Material failure criterion can be defined using the MATF Bulk Data Entry or the MATS1 Bulk Data Entry (for damage initiation/evolution criteria only). Failure of materials is strongly influenced by the loading conditions and thus, the stress state. Hence, several criteria available refer to the notions of stress triaxiality and optionally to the Lode parameter to describe the loading conditions (uniaxial tension, pure shear, plane strain etc).
To describe a failure criterion based on plasticity and stress states, the value stress triaxiality, η , and the lode parameter, ξ , are needed. For shells only, stress triaxiality is needed.
Stress Triaxiality
Stress triaxiality ( η ) is used to differentiate between compressive and tensile loadings and depends on the trace of the stress tensor. It can determine the position of the stress state on the hydrostatic axis shown in Figure 1.
Figure 1. Description of the stress state on hydrostatic axis and deviatoric plane
It is computed as follows:
η = 1 3 σ x x + σ y y + σ z z σ V M MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH3oaAcq GH9aqpdaWcaaqaamaalaaabaGaaGymaaqaaiaaiodaaaWaaeWaceaa cqaHdpWCdaWgaaWcbaGaamiEaiaadIhaaeqaaOGaey4kaSIaeq4Wdm 3aaSbaaSqaaiaadMhacaWG5baabeaakiabgUcaRiabeo8aZnaaBaaa leaacaWG6bGaamOEaaqabaaakiaawIcacaGLPaaaaeaacqaHdpWCda WgaaWcbaGaamOvaiaad2eaaeqaaaaaaaa@4E78@
Where σ V M MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaHdpWCda WgaaWcbaGaamOvaiaad2eaaeqaaaaa@3B00@ is the equivalent von Mises stress.
The values of stress triaxiality vary from MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeyOeI0Iaey OhIukaaa@3852@ to + MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaey4kaSIaey OhIukaaa@3847@ for solids (in practice bounded to -1 and 1) and -2/3 to 2/3 for shells.
Table 1. Stress triaxiality values for some common stress states
Loading condition Solids Shells
Confined compression -1
Biaxial compression -2/3 -2/3
Uniaxial compression -1/3 -1/3
Pure shear 0.0 0.0
Uniaxial tension 1/3 1/3
Plane strain 0.5751 0.5751
Biaxial tension 2/3 2/3
Confined tension 1
Lode Angle
To describe 3D loading conditions, another important quantity is the lode angle ( θ ) given by:
cos 3 θ = 27 2 J 3 σ V M 3 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGJbGaai 4BaiaacohadaqadaqaaiaaiodacqaH4oqCaiaawIcacaGLPaaacqGH 9aqpdaWcaaqaaiaaikdacaaI3aaabaGaaGOmaaaadaWcaaqaaiaadQ eadaWgaaWcbaGaaG4maaqabaaakeaacqaHdpWCdaqhaaWcbaGaamOv aiaad2eaaeaacaaIZaaaaaaaaaa@47AE@
Where J 3 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGkbWaaS baaSqaaiaaiodaaeqaaaaa@391C@ is the third deviatoric invariant.
The lode angle determines the position of the stress state in the deviatoric section. Its value is between 0 (for tension) and π / 3 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaHapaCca GGVaGaaG4maaaa@3A91@ (for compression).
Figure 2. Stress state position on the deviatoric plane depending on the lode angle value
Shear and plane strain condition takes a lode angle value of π / 6 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaHapaCca GGVaGaaGOnaaaa@3A94@ .
Under plane stress hypothesis (for shell elements), the lode angle and the stress triaxiality are linked and thus one for them can be used to recover the other:
cos 3 θ = 27 2 η η 2 1 3 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGJbGaai 4BaiaacohadaqadaqaaiaaiodacqaH4oqCaiaawIcacaGLPaaacqGH 9aqpcqGHsisldaWcaaqaaiaaikdacaaI3aaabaGaaGOmaaaacqaH3o aAdaqadaqaaiabeE7aOnaaCaaaleqabaGaaGOmaaaakiabgkHiTmaa laaabaGaaGymaaqaaiaaiodaaaaacaGLOaGaayzkaaaaaa@4AB8@
As it is much easier to deal with normalized value instead of radians, the lode angle is usually switched by the Lode parameter denoted ξ , given by:
ξ = 1 6 π θ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH+oaEcq GH9aqpcaaIXaGaeyOeI0YaaSaaaeaacaaI2aaabaGaeqiWdahaaiab eI7aXbaa@4018@
The lode parameter's values are:
  • -1.0 in compression
  • In pure shear or plane strain
  • In tension
Supported Failure Criteria
Currently, four failure criteria are supported for Explicit Dynamic Analysis namely, BIQUAD, TSTRN, tabulated failure criteria and INIEVO.
BIQUAD
The BIQUAD criterion is a stress triaxiality based failure criterion mostly used for ductile metals. Its double quadratic curve shape describes the evolution of plastic strain, ε p f MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aa0 baaSqaaiaadchaaeaacaWGMbaaaaaa@39A8@ , at failure with respect to stress triaxiality, η , as shown in the below image.
Figure 3. Failure plastic strain evolution with stress triaxiality for BIQUAD criterion
It then requires five parameters called c1, c2, c3, c4 and c5 respectively corresponding to V1, V2, V3, V4 and V5 value in the MATF Bulk Data Entry. These five values correspond to plastic strain at failure for five different stress states:
  1. Uniaxial compression
  2. Pure shear
  3. Uniaxial tension
  4. Plane strain
  5. Biaxial tension
Note: The parabolic curve computation at high stress triaxiality is made so that c4 is always the minimum value.
For shell elements, strain localization and necking occurring at high strain rate might not be correctly detected as the thickness variation is purely numerical. Thus, failure can be delayed in comparison to an equivalent sized solid element. To avoid that, an additional curve (see the blue curve in the below figure) can be defined for shells using INST parameter (V6), replacing c4 in the high stress triaxiality parabolic curve computation.
Figure 4. Additional failure quadratic curve (in blue) at high stress triaxiality for shells
If enough experimental data is unavailable to identify all the c1, c2, c3, c4 and c5 parameters, a material selector input is also available for BIQUAD criterion. Depending on the keyword MATER value chosen in the list presented above, the c1, c2, c4 and c5 parameters will be automatically computed with respect to c3 value, as shown below.
c 1 = r 1 c 3 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4yaiaaig dacqGH9aqpcaWGYbGaaGymaiabgwSixlaadogacaaIZaaaaa@3E3E@ c 2 = r 2 c 3 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4yaiaaik dacqGH9aqpcaWGYbGaaGOmaiabgwSixlaadogacaaIZaaaaa@3E40@ c 3 = c 3 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4yaiaaio dacqGH9aqpcaWGJbGaaG4maaaa@3A44@ c 4 = r 4 c 3 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4yaiaais dacqGH9aqpcaWGYbGaaGinaiabgwSixlaadogacaaIZaaaaa@3E44@ c 5 = r 5 c 3 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4yaiaaiw dacqGH9aqpcaWGYbGaaGynaiabgwSixlaadogacaaIZaaaaa@3E46@
The value c3 is then the only expected parameter when using material input for BIQUAD criterion. However if no c3 value is specified, a default value of c3 will automatically be set.
Table 2. Automatic parameters settings for MATER keyword
Keyword c3 (Default) r1 r2 r4 r5
MILD 0.60 3.5 1.6 0.6 1.5
HSS 0.50 4.3 1.4 0.6 1.6
UHSS 0.12 5.2 3.1 0.8 3.5
AA5182 0.30 5.0 1.0 0.4 0.8
AA6082 0.17 7.8 3.5 0.6 2.8
PA6GF30 0.10 3.6 0.6 0.5 0.6
PP T40 0.11 10.0 2.7 0.6 0.7
For each timestep, the plastic strain at failure, ε p f ( η ) MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aa0 baaSqaaiaadchaaeaacaWGMbaaaOGaaiikaiabeE7aOjaacMcaaaa@3CB7@ , is estimated according to the stress triaxiality and the parabolic curves. This allows increases to the damage variable accounting for the stress state history:
D = t = 0 Δ ε p ε p f ( η ) MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraiabg2 da9maaqahabaWaaSaaaeaacqGHuoarcqaH1oqzdaWgaaWcbaGaamiC aaqabaaakeaacqaH1oqzdaqhaaWcbaGaamiCaaqaaiaadAgaaaGcca GGOaGaeq4TdGMaaiykaaaaaSqaaiaadshacqGH9aqpcaaIWaaabaGa eyOhIukaniabggHiLdaaaa@493B@
TSTRN
The TSTRN failure criterion is a strain based damage model and is supposed to be fully coupled (DAMAGE keyword activated and D C = 0 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiramaaBa aaleaacaWGdbaabeaakiabg2da9iaaicdaaaa@397B@ ). However, you have the freedom to use it as a failure criterion or a pure output damage variable. It considers a linear evolution of the damage variable between two starting and ending strain values, in tensile loading conditions ( η > 0 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4TdGMaey Opa4JaaGimaaaa@3962@ ):
D = ε ε s t a r t ε e n d ε s t a r t MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraiabg2 da9maalaaabaGaeqyTduMaeyOeI0IaeqyTdu2aaSbaaSqaaiaadoha caWG0bGaamyyaiaadkhacaWG0baabeaaaOqaaiabew7aLnaaBaaale aacaWGLbGaamOBaiaadsgaaeqaaOGaeyOeI0IaeqyTdu2aaSbaaSqa aiaadohacaWG0bGaamyyaiaadkhacaWG0baabeaaaaaaaa@4D35@
A couple of values ε s t a r t MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aaS baaSqaaiaadohacaWG0bGaamyyaiaadkhacaWG0baabeaaaaa@3C8E@ and ε e n d MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aaS baaSqaaiaadwgacaWGUbGaamizaaqabaaaaa@3A8D@ are then needed in the card. V1 and V2 values corresponds to starting and ending von Mises equivalent strain. The von Mises equivalent strain is computed as follows:
ε = 2 3 ε x x 2 ' + ε y y 2 ' + ε z z 2 ' + 2 ε x y 2 + 2 ε y z 2 + 2 ε z x 2 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTduMaey ypa0ZaaOaaaeaadaWcaaqaaiaaikdaaeaacaaIZaaaamaabmaabaGa eqyTdu2aa0baaSqaaiaadIhacaWG4baabaGaaGOmaaaakmaaCaaale qabaGaai4jaaaakiabgUcaRiabew7aLnaaDaaaleaacaWG5bGaamyE aaqaaiaaikdaaaGcdaahaaWcbeqaaiaacEcaaaGccqGHRaWkcqaH1o qzdaqhaaWcbaGaamOEaiaadQhaaeaacaaIYaaaaOWaaWbaaSqabeaa caGGNaaaaOGaey4kaSIaaGOmaiabew7aLnaaDaaaleaacaWG4bGaam yEaaqaaiaaikdaaaGccqGHRaWkcaaIYaGaeqyTdu2aa0baaSqaaiaa dMhacaWG6baabaGaaGOmaaaakiabgUcaRiaaikdacqaH1oqzdaqhaa WcbaGaamOEaiaadIhaaeaacaaIYaaaaaGccaGLOaGaayzkaaaaleqa aaaa@6095@
Where ε ' MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aaW baaSqabeaacaGGNaaaaaaa@3872@ is the deviatoric strain tensor.
If V3 and V4 values are specified, they correspond to starting and ending major principal strain.
ε = max ( ε 1 , ε 2 , ε 3 ) > 0 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTduMaey ypa0JaciyBaiaacggacaGG4bGaaiikaiabew7aLnaaBaaaleaacaaI XaaabeaakiaacYcacqaH1oqzdaWgaaWcbaGaaGOmaaqabaGccaGGSa GaeqyTdu2aaSbaaSqaaiaaiodaaeqaaOGaaiykaiabg6da+iaaicda aaa@47BB@
Note: V3 and V4 values are always prioritized when both V1/V2 and V3/V4 pairs are specified.
Tabulated failure criteria
The TAB failure criterion is used to give as much freedom as possible to describe a plastic strain based tabulated criterion. The TABLEMD entry defined by EPS_TID describes the map showing the evolution of plastic strain at failure, ε p f MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aa0 baaSqaaiaadchaaeaacaWGMbaaaaaa@39A8@ , with respect to stress triaxiality and, optionally for solid elements, with lode parameter, ξ , as shown in Figure 5.
Figure 5. Tabulated failure criterion map showing the evolution of plastic strain at failure with respect to stress triaxiality and lode parameter
For solid elements, the entire map with all possible couple of values, ( η , ξ ) MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaiikaiabeE 7aOjaacYcacqaH+oaEcaGGPaaaaa@3B6C@ , is considered. However, for shells stress triaxiality and lode parameter are linked due to plane stress conditions. Hence, only the plane stress (blue line in Figure 5) is considered.
The V1 value is a scale factor that allows you to quickly increase or decrease in entire map.
The damage variable evolution is given by a specific formula using the parameter in defined in V2 value:
D = t = 0 Δ ε p ε p f ( η , ξ ) n D 1 1 n MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraiabg2 da9maaqahabaWaaSaaaeaacqGHuoarcqaH1oqzdaWgaaWcbaGaamiC aaqabaaakeaacqaH1oqzdaqhaaWcbaGaamiCaaqaaiaadAgaaaGcca GGOaGaeq4TdGMaaiilaiabe67a4jaacMcaaaaaleaacaWG0bGaeyyp a0JaaGimaaqaaiabg6HiLcqdcqGHris5aOGaeyyXICTaamOBaiabgw SixlaadseadaahaaWcbeqaamaabmaabaGaaGymaiabgkHiTmaalaaa baGaaGymaaqaaiaad6gaaaaacaGLOaGaayzkaaaaaaaa@5724@
Thus, including its own current value, the damage variable evolution is taking into account the stress state history but also the damage history. The exponent n MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOBaaaa@36E6@ allows to indirectly change the shape of the damage evolution with respect to plastic strain as presented in Figure 6. The increase of the n MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOBaaaa@36E6@ exponent parameter tends to delay the stress softening effect as shown.
Figure 6. Effect of n parameter on the damage versus plastic strain evolution (left picture) and effect of n parameter on a single element uniaxial tension behavior (right picture)
You can use the TAB criterion defining only the first line of parameters (EPS_TID, V1 and V2). In this case, like any other criterion available, you can activate the element deletion using DAMAGE, chose the beginning of stress softening with the constant value for critical damage DC and the shape of the stress softening using EXP.
Another approach of stress softening approach with TAB criterion is called the necking-controlled approach.
To use this new approach, the two first parameters of the second line INST_TID and V6 must be defined. INST_TID defines the ID of a TABLEMD entry defining a map showing the evolution of the plastic strain value (denoted ε p l o c MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aa0 baaSqaaiaadchaaeaacaWGSbGaam4Baiaadogaaaaaaa@3B8A@ ) for which necking instability and thus strain localization starts, with respect to stress triaxiality and, optionally, lode parameter. It is an instability limit curve or map mostly defined at high stress triaxiality as the one described above for BIQUAD criterion in Figure 3 and is supposed to be lower than the failure curve/map to have an effect. It can be used with solids or shells.
This INST second map allows to compute the evolution of a new variable called necking-triggering variable and denoted f MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOzaaaa@36DF@ . Its evolution is very similar to the damage variable one:
f = t = 0 Δ ε p ε p l o c ( η , ξ ) n f 1 1 n MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOzaiabg2 da9maaqahabaWaaSaaaeaacqGHuoarcqaH1oqzdaWgaaWcbaGaamiC aaqabaaakeaacqaH1oqzdaqhaaWcbaGaamiCaaqaaiaadYgacaWGVb Gaam4yaaaakiaacIcacqaH3oaAcaGGSaGaeqOVdGNaaiykaaaaaSqa aiaadshacqGH9aqpcaaIWaaabaGaeyOhIukaniabggHiLdGccqGHfl Y1caWGUbGaeyyXICTaamOzamaaCaaaleqabaWaaeWaaeaacaaIXaGa eyOeI0YaaSaaaeaacaaIXaaabaGaamOBaaaaaiaawIcacaGLPaaaaa aaaa@594A@
Once this variable reaches the value 1, a stress softening is triggered (defined by Comment 12 in the MATF Bulk Data Entry). However, instead of using the constant value, D C MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiramaaBa aaleaacaWGdbaabeaaaaa@37B1@ , in the MATF entry, the parameter, D C MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiramaaBa aaleaacaWGdbaabeaaaaa@37B1@ , becomes an integration point. Thus D C MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiramaaBa aaleaacaWGdbaabeaaaaa@37B1@ can be very different from one element to another depending on the history of the element stress state.
Thus, when INST_TID is used, the D C MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiramaaBa aaleaacaWGdbaabeaaaaa@37B1@ value corresponds to the value taken by the damage variable D MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraaaa@36BD@ at the exact moment when f MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOzaaaa@36DF@ reaches or overtakes the value 1. In other words, D C MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiramaaBa aaleaacaWGdbaabeaaaaa@37B1@ is the D MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraaaa@36BD@ value when the necking criterion is reached the first time. Then, D C MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiramaaBa aaleaacaWGdbaabeaaaaa@37B1@ remains untouched until the end of the simulation.
D = Δ D f = Δ f D C = 1 while f < 1 D when f 1 σ = σ e f f 1 D D c 1 D c exp MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGceaqabeaacaWGeb Gaeyypa0Zaa8qaaeaacqGHuoarcaWGebaaleqabeqdcqGHRiI8aaGc baGaamOzaiabg2da9maapeaabaGaeyiLdqKaamOzaaWcbeqab0Gaey 4kIipaaOqaaiaadseadaWgaaWcbaGaam4qaaqabaGccqGH9aqpdaGa baqaauaabeqaceaaaeaafaqabeqadaaabaGaaGymaaqaaiaabEhaca qGObGaaeyAaiaabYgacaqGLbaabaGaamOzaiabgYda8iaaigdaaaaa baqbaeqabeWaaaqaaiaadseaaeaacaqG3bGaaeiAaiaabwgacaqGUb aabaGaamOzaiabgwMiZkaaigdaaaaaaaGaay5EaaaabaGaeq4WdmNa eyypa0Jaeq4Wdm3aaSbaaSqaaiaadwgacaWGMbGaamOzaaqabaGcda qadaqaaiaaigdacqGHsisldaqadaqaamaalaaabaGaamiraiabgkHi TiaadseadaWgaaWcbaGaam4yaaqabaaakeaacaaIXaGaeyOeI0Iaam iramaaBaaaleaacaWGJbaabeaaaaaakiaawIcacaGLPaaadaahaaWc beqaaiGacwgacaGG4bGaaiiCaaaaaOGaayjkaiaawMcaaaaaaa@6CE4@
Unlike the D C MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiramaaBa aaleaacaWGdbaabeaaaaa@37B1@ parameter, the exponent (EXP) is a constant parameter over all elements.
This necking-controlled approach can offer a higher predictivity for a large range of stress state but needs to define an instability map especially at high stress triaxiality when necking is more likely to happen.
Finally, parameters V7 and V8 values are stress triaxiality boundaries for element size scaling defined below. If this pair of values are defined, the size scaling only occurs when:
V 7 < η < V 8 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvaiaaiE dacqGH8aapcqaH3oaAcqGH8aapcaWGwbGaaGioaaaa@3CE1@
Damage initiation and evolution (INIEVO)
INIEVO failure criterion is very specific and provides the ability to define a failure approach based on the use of a DMGINI Bulk Data Entry and, optionally a DMGEVO Bulk Data Entry.
For the DMGINI Bulk Data Entry, only DUCTILE criterion is available. For the DMGEVO Bulk Data Entry, only DISP and ENERGY evolution are available.
This criterion can be defined using two methods:
  1. The DAMAGE continuation line in the MATS1 Bulk Data Entry. This method is supported both for Implicit and Explicit Dynamic Analysis.
  2. CRI=INIEVO in the MATF Bulk Data Entry. This method is supported only for Explicit Dynamic Analysis.
Note: For INIEVO, strain rate dependency and element size dependency are not available.
