AESYMXZ
I/O Options and Subcase Information Entry Aerodynamic XZ plane of symmetry flag. The AESYMXZ command can be used in the case control section to support symmetric models about the centerline.
AESYMXZ = option
| Argument | Options | Description |
| option | <SYMMETRIC,
                                        ANTISYMMETRIC,
                                        ASYMMETRIC> Default: See Comments |
- If AESYMXZ is not present in case control, aerodynamic XZ symmetry will be determined from the SYMXZ field of the AEROS Bulk Data Entry for static aeroelastic analysis.
- If AESYMXZ is present above the subcase level, it is applied to all subcases until overridden.
