ACCEL1
Bulk Data Entry Defines static acceleration loads at specific GRID points in the model.
| ACCEL1 | SID | CID | A | N | N | N | |||
| GID1 | GID2 | etc. |
| ACCEL1 | 100 | 0 | 2.0 | 2.0 | 1.0 | 3.0 | |||
| 2 | 4 | 6 | 8 | THRU | 30 | BY | 2 | ||
| 1200 | THRU | 1300 |
| SID | Acceleration load set
                                identification number. (Integer > 0) | |
| CID | Coordinate system
 (Integer ≥ 0, or blank) | |
| A | Scale factor for the
                                acceleration load vector. (Real) | |
| N,N,N | Acceleration load vector
                                components in the coordinate system CID. (Real, a minimum of one Ni should not be set to 0.0) | |
| GIDi | Grid point identification
                                numbers at which the acceleration load is applied. The
                                    THRU and BY keywords can also
                                be used to specify grids. (Integer > 0) |
- The acceleration load applied to referenced
                    grid points in the model is given by:Where,
- Acceleration load.
- Vector with components N, N, and N.
- Scale factor defined by field A.
- The acceleration loads specified in the ACCEL1 entry can be combined with other loads, such as FORCE, MOMENT, GRAV, ACCEL, and ACCEL2, through the LOAD Subcase Information Entry. The SID on the ACCEL entry should be unique with regard to any other load entry.
- The acceleration load does not include effects, due to mass on SPOINTs.
- This card is represented as a force load in HyperMesh.
