Graph Studio Kubernetes Requirements
This topic gives an overview of the general infrastructure requirements for Graph Studio Kubernetes (K8s) integration. Additional software, network infrastructure, and permission-related requirements are included in the deployment instructions for each of the cloud service providers (see Setting up K8s Infrastructure for Dynamic Deployments).
Supported Kubernetes Versions
The latest stable Kubernetes versions are supported for all cloud service providers.
File Storage Requirements
A network file system (NFS) is required for shared file storage between Graph Studio and the dynamic applications. You are required to create the file system. However, Graph Studio automatically mounts the NFS to the nodes when Graph Lakehouse, Graph Studio Unstructured, or Elasticsearch pods are deployed. See Platform Shared File Storage Requirements for more information.
Node Pool Requirements
There are three types of node pools or node groups that you are required to configure for integration with Graph Studio. In addition to the scripts for creating and configuring the K8s cluster, Altair supplies configuration files to use as templates for defining the policies for each type of node pool. The node pools can be configured as static or autoscaling.
Operator Node Pool
An Operator node pool is tuned to run operator pods. Operator pods manage the application pods and control the K8s resources of the applications that are deployed in the node pools. There is one operator for each application: Graph Lakehouse, Elasticsearch, and Graph Studio Agent and Graph Studio Unstructured. Graph Studio deploys and manages the operator pods. With the help of the operators, Graph Studio orchestrates the provisioning and deprovisioning of the application nodes and pods. Since the operators in the Operator node pool are required to be active at all times, operator pods are designed to be very small and use very few resources. They can be deployed on standard, small-sized cloud instances.
AnzoGraph Node Pool
An Graph Lakehouse node pool is tuned to run Graph Lakehouse pods. Graph Lakehouse node pools are typically configured to auto-scale so that nodes are not deployed unless a user requests an Graph Lakehouse environment for loading a graphmart or running queries against the data in a graphmart.
Dynamic Node Pool
The Dynamic node pool is tuned to run Elasticsearch, Graph Studio Agent, and Graph Studio Unstructured (AU) pods. Dynamic node pools are also typically configured to auto-scale so that nodes are not deployed unless a user requests an environment for running a structured or unstructured pipeline.
The diagram below shows the K8s cluster architecture with the required node pools.
For Amazon EKS deployments, there is a fourth type of required node group. The additional type, called a Common node group, is tuned to run K8s service pods, such as Cluster Autoscalers and Load Balancers.
For guidance on choosing the instance types and sizes for the nodes in the required node pools, see Compute Resource Planning.
Container Registry Requirements
You are not required to set up an internal container registry for Graph Studio and K8s integration. However, if your K8s cluster will not have outbound internet access for retrieving container images from the Altair Graph repository, you will need to create a container registry through your Cloud Service Provider.
