Access the HTTP Client Interface
In addition to the SPARQL HTTP(S) endpoint that enables users to send SPARQL queries to Graph Studio over HTTP, Graph Studio provides an HTTP(S) servlet that can be used to invoke Graph Studio client operations over HTTP. The client servlet enables external systems to interact with Graph Studio semantic services as well as custom services. It also enables remote servers to interact with Graph Studio without needing the Graph Studio command line interface.
HTTP Methods and Options
The Graph Studio client servlet accepts HTTP GET and POST methods. GET is used for operations that retrieve data, and POST is used for update operations that add or remove data. Update operations must use the POST method, and read operations can be submitted using GET or POST.
Client Servlet Base URL
Use the following URL to access Graph Studio services via the HTTP client servlet. The table below describes each URL component:
<protocol>://<hostname>:<port>/anzoclient/<client_operation>
For example:
https://10.100.10.20:8443/anzoclient/call
| Option | Description |
| protocol | The protocol to use for the connection: http for HTTP protocol or https for SSL protocol. |
| hostname | The DNS name or IP address of the Graph Studio server. |
| port | The port for the endpoint. The port that you specify depends on the protocol that you choose. By default, the HTTP port is 80 and the HTTPS port is 443. To view the ports that are configured for your Graph Studio instance, see Server Settings in the Administration menu. |
| anzoclient | Required keyword for the client servlet. |
| client_operation | The type of Graph Studio client operation to invoke. The list below provides an overview of the supported operation types. For more information about the operations, see Client Operations below.
Client Operations
This section provides usage information and examples for each of the Graph Studio client operations.
Call
The call operation invokes a semantic service. Identify the service to call by providing the URI for the service in the request header. The call operation is supported with HTTP GET and POST methods. When including RDF data as input to the service, the request must use the POST method.
Call Header Options
Call operations support the following header parameters. Only the uri parameter is required:
- uri: Required parameter that specifies the URI of the semantic service to invoke.
- mimeType, Content-Type, or format: Include one of these optional parameters to specify the MIME type for the RDF serialization used in the request body as well as the response from the service. The default type is application/json if the header does not specify the format. For more information about the supported RDF serialization types, see Format Options.
Call Body Options
If the call operation supplies data as input to the service, include the data in the request body. The data must be serialized as specified in the request header, or application/json if the header does not specify a serialization type.
Call Examples
The following cURL example uses a GET call to invoke a health check service.
curl https://10.100.10.20:8443/anzoclient/call \ --user sysadmin:123 \ --header 'uri: http://www.csi.com/service/genericIngestManager#healthCheck'
The example below uses a POST call to invoke a service operation. The call passes in a request data set that is serialized as RDF JSON.
--header 'Content-Type: application/json' \
--header 'uri: http://someServiceURI#someOperation' \
--data '{"subject" : {"objectType": "uri" ,"value" : "urn://test"},
"predicate" : "urn://predicate",
"object" : {"objectType": "uri" ,"value" : "urn://object"},
"namedGraphUri" : "urn://ng"}'
The example below uses a POST call to invoke a service operation. The call passes in a request data set that is serialized as TriG.
--header 'Content-Type: application/x-trig' \
--data '<urn://ng> { <urn://test> <urn://predicate> <urn://object> .}'
Add
The add operation adds statements to the Graph Studio graphstore. Add is supported with the HTTP POST method. The header can include mimeType, Content-Type, or format to specify the MIME type for the RDF serialization used in the request body as well as the response from the service. The default type is application/json if the header does not specify the format. For more information about the supported RDF serialization types, see Format Options. The request body includes the statements to add.
Add Examples
The following example add operation uses cURL to issue a POST call to add a statement to the graphstore. The statement is specified in Graph Studio JSON RDF serialization format.
curl https://10.100.10.20:8443/anzoclient/add \
Remove
The remove operation deletes statements from the Graph Studio graphstore. Remove is supported with the HTTP POST method. The header can include mimeType, Content-Type, or format to specify the MIME type for the RDF serialization used in the request body as well as the response from the service. The default type is application/json if the header does not specify the format. For more information about the supported RDF serialization types, see Format Options. The request body specifies the statements to remove.
Remove Examples
The following example remove operation uses cURL to issue a POST call to remove a statement from the graphstore. The statement is specified in Graph Studio JSON RDF serialization format.
curl https://10.100.10.20:8443/anzoclient/remove \
Get
The get operation retrieves a named graph from the Graph Studio graphstore. The get operation is supported with HTTP GET and POST methods. The named graph URI that contains the contents to retrieve can be included as a query parameter or as a uri parameter in the request body. The get operation also returns the metadata graph, which is equivalent to running anzo get -m <named_graph_uri> with the Graph Studio admin CLI. The header can include mimeType, Content-Type, or format to specify the MIME type for the RDF serialization used to format the response from the service. The default type is application/json if the header does not specify the format.
Get Examples
The following example get operation uses cURL to retrieve the contents of a named graph.
curl -k -XPOST https://10.100.10.20:8443/anzoclient/get --user sysadmin:123
--data-urlencode
"uri=http://cambridgesemantics.com/Graphmart/9da211618a15476daa10cead2292d8e7"
This example uses Python with requests:
import requests
url = "https://10.100.10.20:8443/anzoclient/get"
data = {"uri": "http://cambridgesemantics.com/Graphmart/9da211618a15476daa10cead2292d8e7"}
username = "sysadmin"
password = "123"
r = requests.post(url, data=data, auth=(username, password), verify=False)
print (r.text
Find
The find operation finds the statements in the graphstore that match the pattern that is specified in the request. The find operation is supported with HTTP GET and POST methods. Header options are not applicable. The list below describes each of the supported parameters. These parameters can be included as query parameters in the URL or as parameters in the request body:
- graph: The named graph URI for the find pattern.
- sub: The subject of the find pattern.
- pred: The predicate of the find pattern.
- lit: The object of the find pattern if that object is a literal value.
- uri: The object URI of the find pattern if that object is a URI.
- type: If the object is a literal, this parameter can be used to specify the data type of the literal value.
- lang: If the object is a literal, this parameter can be used to specify the language of the literal value.
Results returned by the find operation are in Graph Studio JSON RDF serialization format. See Graph Studio JSON RDF Serialization below for details.
Find Examples
The following example find operation (using the GET HTTP method) finds all of the statements in the graphstore with predicate http://w3.org/1999/02/22-rdf-syntax-ns#type and an object URI of http://cambridgesemantics.com/ontologies/2009/05/LinkedData#LinkedDataSet. The parameters are specified as query parameters in the URL.
curl https://10.100.10.20:8443/anzoclient/find?pred=http://www.w3.org/1999/02/22-rdf-syntax-ns%23type&uri=http://cambridgesemantics.com/ontologies/2009/05/LinkedData%23LinkedDataSet' \ --user sysadmin:123
The example below finds the same statements but issues a POST call. The URL-encoded parameters are specified in the request body.
curl https://10.100.10.20:8443/anzoclient/find \ --user sysadmin:123 --data 'pred=http%3A%2F%2Fwww.w3.org%2F1999%2F02%2F22-rdf-syntax-ns%23type&uri=http%3A%2F%2Fcambridgesemantics.com%2Fontologies%2F2009%2F05%2FLinkedData%23LinkedDataSet'
Graph Studio's JSON RDF serialization standard is straightforward but differs from the common public JSON RDF serialization standards. In Graph Studio JSON serialization format, a set of statements (quads) are represented as an array of JSON objects. Each JSON object (statement) is defined as a key/value pair, where the key specifies the component of the statement, i.e., the subject, predicate, object, or namedGraphUri. Depending on the component, properties such as the component's value and data type are specified in nested objects.
The following example array shows Graph Studio's JSON serialization. The list below the example describes the structure.
"subject" : {
"object" : {
"subject" : {
"predicate" : "urn://predicate2",
"object" : {
"objectType": "literal" ,
"value" : "test literal",
"dataType" : "http://www.w3.org/2001/XMLSchema#string"
- subject is a JSON object with two properties:
- objectType: The resource type of the subject value. This is either a "uri" or "bnode" (blank node).
- value: The blank node value or a string literal that specifies the URI.
- predicate is a string literal that specifies the predicate URI.
- object is a JSON object with two required properties and two optional properties:
- objectType: Required property that specifies whether the object is a "uri," "literal," or "bnode."
- value: Required property that specifies the string representation of the object value.
- dataType: Optional property for use if the objectType is "literal." This property describes the data type of the literal value. It is a string literal of the XSD data type URI. For example: "http://www.w3.org/2001/XMLSchema#string"
- language:Optional property for use if the objectType is "literal." This property describes the language of the literal value.
- namedGraphUri is a string literal that specifies the named graph URI.
