Math Functions
This topic describes the mathematical functions in Graph Lakehouse.
  • ABS: Calculates the absolute value of the specified number.
  • ADD: Adds two numeric values.
  • AVG: Calculates the average (arithmetic mean) value for a group of numbers.
  • BASE: Converts a number to the specified base and returns a text representation.
  • CEIL: Rounds up a numeric value to the nearest integer.
  • COS: Calculates the cosine of an angle.
  • EXP: Raises e to the specified power.
  • FACT: Calculates the factorial of the specified number.
  • FLOOR: Rounds down a numeric value to the nearest integer.
  • HAMMING_DIST: Calculates the hamming distance between two values.
  • HAVERSINE_DIST: Computes the haversine distance between two latitude and longitude values.
  • LN: Calculates the natural logarithm of a double value.
  • LOG: Calculates the specified base logarithm of a double value.
  • LOG2: Calculates the base two logarithm of a double value.
  • MOD: Calculates the modulo of the division between two numbers.
  • PI: Returns the value for PI.
  • POWER: Raises the specified number to the specified power.
  • RADIANS: Converts to radians an angle value that is in degrees.
  • RAND: Returns a random double value between 0 and 1.
  • RANDBETWEEN: Returns a random integer that falls between two specified integers.
  • ROUND: Rounds a numeric value to the nearest integer.
  • ROUNDDOWN: Rounds a numeric value down to the specified number of digits.
  • ROUNDUP: Rounds a numeric value up to the specified number of digits.
  • SIN: Calculates the sine of an angle.
  • SQRT: Calculates the square root of a number.
  • TAN: Calculates the tangent of an angle.
Typographical Conventions
The following list describes the conventions used to document function syntax:
  • CAPS: Although SPARQL is case-insensitive, SPARQL keywords in this section are written in uppercase for readability.
  • [ argument ]: Brackets indicate an optional argument or keyword.
  • |: Means OR. Indicates that you can use one or more of the specified options.
ABS
This function calculates the absolute value of the specified number.
ABS(number)
Argument Type Description
number numeric The numeric value for which to calculate the absolute value.
Returns
Type Description
number The absolute value.
The following example queries the sample Tickit data to find the absolute value of the price per ticket minus the total price paid for each of the ticket listings.
PREFIX tickit: <http://anzograph.com/tickit/>
SELECT ?listing (ABS(?priceper - ?total) AS ?absolute_value)
FROM <http://anzograph.com/tickit>
WHERE {
  ?listing tickit:priceperticket ?priceper .
  ?listing tickit:totalprice ?total .
ORDER BY ?listing
LIMIT 10
listing                                   | absolute_value
http://anzograph.com/tickit/listing1      |           1638
http://anzograph.com/tickit/listing10     |           2955
http://anzograph.com/tickit/listing100    |           3059
http://anzograph.com/tickit/listing1000   |            928
http://anzograph.com/tickit/listing10000  |           1350
http://anzograph.com/tickit/listing100001 |            410
http://anzograph.com/tickit/listing100002 |           5502
http://anzograph.com/tickit/listing100003 |           3146
http://anzograph.com/tickit/listing100004 |            368
http://anzograph.com/tickit/listing100006 |           6960
10 rows
ADD
This function adds two numeric values.
ADD(value1, value2)
value1 numeric The first numeric value to add.
value2 numeric The second numeric value to add.
Returns
Type Description
number The result of the addition operation.
AVG
This function calculates the average (arithmetic mean) value for a group of numbers.
AVG(number)
number numeric The numeric value for which to calculate the average.
Returns
Type Description
number The arithmetic mean of the input values.
Examples
The following example queries the sample Tickit data set to determine the average number of seats in the venues in each state. Since the results clause contains a non-aggregated variable (?state), a GROUP BY clause is required for grouping on ?state.
SELECT ?state (ROUND(AVG(?seats)) AS ?avg_seats)
WHERE {
  ?s tickit:venuestate ?state .
  ?s tickit:venueseats ?seats .
GROUP BY ?state
ORDER BY ?state
state | avg_seats
CA    |     50309
CO    |     63285
DC    |     41888
FL    |     62603
GA    |     60620
IL    |     48244
IN    |     63000
LA    |     72000
MA    |     54342
MD    |     70229
MI    |     53391
MN    |     64035
MO    |     59217
NC    |     73298
NJ    |     80242
NY    |     48764
OH    |     56035
ON    |     50516
PA    |     53931
TN    |     68804
TX    |     56915
WA    |     57058
WI    |     57561
23 rows
The query below calculates the average total price for all of the listings in the sample Tickit data set:
SELECT (AVG(?numtickets*?priceperticket) AS ?avg_total_price)
WHERE {
  ?listing tickit:priceperticket ?priceperticket .
  ?listing tickit:numtickets ?numtickets .
avg_total_price
3034.42
1 rows
BASE
This function converts a number into the specified base and returns a text representation of the calculated value.
BASE(number, base [, min_length ])
number int The integer to convert. Valid values are 0–2^53.
base int The radix to convert the number to. Valid values are 2–36.
min_length int Optional argument that specifies the minimum length of the returned string. If the result is shorter than the minimum length, leading zeros are added to the result so that it reaches the minimum length. Valid values are 0–255.
Returns
Type Description
string The text representation of the base.
CEIL
This function rounds up a numeric value to the nearest integer if the value has a fractional part. CEILING returns the value itself if it is a whole number.
CEIL(number)
number numeric The numeric value to round up.
Returns
Type Description
number The rounded up value.
COS
This function calculates the cosine of the specified angle.
COS(angle)
angle double The angle in radians (double data type) to calculate the cosine for. If you have angle values in degrees, you can use RADIANS to convert the degrees to radians.
Returns
Type Description
double The cosine of the angle.
EXP
This function raises the base of the natural logarithms, e, to the specified power.
EXP(power)
power double The number to raise e to.
Returns
Type Description
double E raised to the specified power.
FACT
This function calculates the factorial of the specified number.
FACT(number)
number int The number for which to calculate the factorial.
Returns
Type Description
int The factorial of the input values.
FLOOR
This function rounds down a numeric value to the nearest integer if the value has a fractional part. FLOOR returns the value itself if it is a whole number.
FLOOR(number)
number numeric The numeric value to round down.
Returns
Type Description
number The rounded down value.
HAMMING_DIST
This function calculates the hamming distance between two values.
HAMMING_DIST(number1, number2)
number1 long The first number.
number2 long The second number.
Returns
Type Description
int The hamming distance.
HAVERSINE_DIST
This function computes the haversine distance between two latitude and longitude values and returns the distance in kilometers.
HAVERSINE_DIST(latitude1, longitude1, latitude2, longitude2)
latitude1 double The first latitude value.
longitude1 double The first longitude value.
latitude2 double The second latitude value.
longitude2 double The second longitude value.
Returns
Type Description
double The distance in kilometers.
LN
This function calculates the natural logarithm of a double value.
LN(number)
number double The double value for which to calculate the natural logarithm.
Returns
Type Description
double The natural logarithm of the input value.
LOG
This function calculates the specified base logarithm of a double value.
LOG(number [, base ])
number double The double value for which to calculate the base logarithm.
base double An optional double value that specifies the base for the logarithm. If omitted, base e is used.
Returns
Type Description
double The base logarithm of the input value.
LOG2
This function calculates the base two logarithm of a double value.
LOG2(number)
number double, float The double value for which to calculate the base 2 logarithm.
Returns
Type Description
double, float The base two logarithm of the input value.
The example below determines the base two logarithm of the quantity of tickets sold for each ticket listing.
SELECT ?sale ?qtysold (LOG2(?qtysold) AS ?qtylog)
WHERE {
  ?sale <http://anzograph.com/tickit/qtysold> ?qtysold .
ORDER BY ?sale
LIMIT 10
sale                                    | qtysold | qtylog
http://anzograph.com/tickit/sales1      |       4 |       2
http://anzograph.com/tickit/sales10     |       1 |       0
http://anzograph.com/tickit/sales100    |       2 |       1
http://anzograph.com/tickit/sales1000   |       3 | 1.58496
http://anzograph.com/tickit/sales10000  |       1 |       0
http://anzograph.com/tickit/sales100000 |       1 |       0
http://anzograph.com/tickit/sales100001 |       2 |       1
http://anzograph.com/tickit/sales100002 |       1 |       0
http://anzograph.com/tickit/sales100003 |       2 |       1
http://anzograph.com/tickit/sales100004 |       2 |       1
10 rows
MOD
This function calculates the modulo or remainder of the division between two numbers.
The calculation of negative operands depends on C++ and your underlying hardware. Graph Lakehouse uses FMOD for floating point operands and % for all other data types.
MOD(number, divisor)
number numeric The number that is the dividend in the equation.
divisor numeric The number to divide the dividend by.
Returns
Type Description
number The modulo between the input numbers.
The following example queries the sample Tickit dataset to find the modulo between the number of seats in each venue and the population of the city the venue is in.
SELECT ?venue ?city (MOD(?pop, ?seats) AS ?modulo)
WHERE {
  ?s tickit:venuename ?venue .
  ?s tickit:venuecitypop ?pop .
  ?s tickit:venuecity ?city .
ORDER BY ?venue
LIMIT 10
venue                    | city          | modulo
ARCO Arena               | Sacramento    |    638
AT&T Park                | San Francisco |  16678
Angel Stadium of Anaheim | Anaheim       |  26011
Arrowhead Stadium        | Kansas City   |  62532
Bank of America Stadium  | Charlotte     |  71742
Busch Stadium            | St. Louis     |  20109
Citizens Bank Park       | Philadelphia  |  42008
Cleveland Browns Stadium | Cleveland     |  30815
Comerica Park            | Detroit       |   3483
Coors Field              | Denver        |  45263
10 rows
PI
This function returns the value for PI.
PI()
Returns
Type Description
double The PI value.
POWER
This function raises the specified number to the specified power.
POWER(value, power)
value numeric The number to raise by the power.
power numeric The number to raise value by.
Returns
Type Description
number The result of value raised to the specified power.
The following example queries the sample Tickit dataset to raise the total number of tickets sold for each event by the power of 2:
SELECT ?event (POWER(?tickets, 2) AS ?power_total)
WHERE {
  SELECT ?event (sum(?qty) as ?tickets)
  WHERE {
    ?sales tickit:qtysold ?qty .
    ?sales tickit:eventid ?eventid .
    ?eventid tickit:eventname ?event .
GROUP BY ?event
ORDER BY desc(?tickets)
LIMIT 10
event            | power_total
Mamma Mia!       | 1.3381e+07
Spring Awakening | 9.15062e+06
The Country Girl | 8.24264e+06
Jersey Boys      | 7.73396e+06
Macbeth          | 7.46929e+06
Chicago          | 6.42622e+06
Legally Blonde   | 5.16198e+06
Spamalot         | 4.8356e+06
Rhinoceros       | 3.6481e+06
Thurgood         | 3.58724e+06
10 rows
RADIANS
This function converts to radians an angle value that is in degrees.
RADIANS(angle)
angle double The angle value to convert to radians.
Returns
Type Description
double The angle in radians.
RAND
This function returns a random double value between 0 and 1, including 0 and excluding 1.
RAND()
Returns
Type Description
double The random value between 0 and 1.
RANDBETWEEN
This function returns a random integer that falls between the two specified integers. The two integers are included as options to be returned.
RANDBETWEEN(low_number, high_number)
low_number int The lowest integer in the range of values.
high_number int The highest integer in the range of values.
Returns
Type Description
int The random value between the given low and high numbers.
ROUND
This function rounds a numeric value to the nearest integer.
ROUND(number)
number numeric The number to round to the nearest integer.
Returns
Type Description
number The rounded value.
ROUNDDOWN
This function rounds a numeric value down to the specified number of digits.
ROUNDDOWN(number, num_digits)
number numeric The number to round down.
num_digits int An integer that specifies the number of digits to round down to.
Returns
Type Description
ROUNDUP
This function rounds a numeric value up to the specified number of digits.
ROUNDUP(number, num_digits)
number numeric The number to round up.
num_digits int An integer that specifies the number of digits to round up to.
Returns
Type Description
SIN
This function calculates the sine of the specified angle.
SIN(angle)
angle double The angle in radians to calculate the sine for. If you have angle values in degrees, you can use RADIANS to convert the degrees to radians.
Returns
Type Description
double The sine of the angle.
SQRT
This function calculates the square root of the specified number.
SQRT(number)
number numeric The number for which to calculate the square root.
Returns
Type Description
double The square root of the input value.
TAN
This function calculates the tangent of the specified angle.
TAN(angle)
angle double The angle in radians to calculate the tangent for. If you have angle values in degrees, you can use RADIANS to convert the degrees to radians.
Returns
Type Description
double The tangent of the angle.
