Cypher Expressions, Variables, and Parameters
This section describes Graph Lakehouse compatibility with Cypher expression, variables, and parameter features based on the Cypher Query Language Reference:
- Expressions (Supported)
- CASE expressions (Supported)
- Variables (Supported)
- Parameters (Not Supported)
Valid expressions in Cipher may include or be specified as any of the following:
- A decimal (integer or double) literal. For example: 13, -40000, 3.14, 6.022E23.
- A hexadecimal integer literal (starting with 0x). For example: 0x13zf, 0xFC3A9, -0x66eff.
- An octal integer literal (starting with zero). For example: 01372, 02127, -05671.
- A string literal. For example: 'Hello', "World".
- A boolean literal. For example: true, false, TRUE, FALSE.
- A variable. For example: n, x, rel, myFancyVariable, .
- A property. For example: n.prop, x.prop, rel.thisProperty, myFancyVariable.
- A dynamic property. For example: n["prop"], rel[n.city + n.zip], map[coll[0]].
- A parameter. For example: $param, $0
- A list of expressions. For example: ['a', 'b'], [1, 2, 3], ['a', 2, n.property, $param], [ ].
- A function call. For example: length(p), nodes(p).
- An aggregate function. For example: avg(x.prop), count(*).
- A path-pattern. For example: (a)-[]->()<-[]-(b).
- An operator application. For example: 1 + 2 and 3 < 4.
- A predicate expression that returns true or false. For example: a.prop = 'Hello', length(p) > 36 10, exists(a.name).
- A case-sensitive string matching expression. For example: a.surname STARTS WITH 'Sven', a.surname ENDS WITH 'son' or a.surname CONTAINS 'son'
- A CASE expression.
Escape Characters
String literals can contain the following escape sequences:
| Character | Description |
| \t | Tab |
| \b | Backspace |
| \n | Newline |
| \r | Carriage return |
| \f | Form feed |
| \' | Single quote |
| \" | Double quote |
| \\ | Backslash |
| \uxxxx | Unicode UTF-16 code point (4 hex digits must follow the \u) |
| \Uxxxxxxxx | Unicode UTF-32 code point (8 hex digits must follow the \U) |
Generic conditional expressions may be expressed using the well-known CASE construct. For example:
CASE test WHEN value THEN result [WHEN ...] [ELSE default] END
Two variants of CASE exist within Cypher: the simple form, which allows an expression to be compared against multiple values, and the generic form, which allows multiple conditional statements to be expressed.
When you reference parts of a pattern or a query, you do so by naming them. The names you give the different parts are called variables. For example:
MATCH (n)-[]->(b) RETURN b
In this example, the variables are n and b.
Variable names are case-sensitive, and can contain underscores and alphanumeric characters (a-z, 0-9), but must always start with a letter. To include other characters are needed, you can escape them with the single back quote ( ` ) character. The same rule applies to property names.
The Cypher language specification supports querying with parameters. However, the current Graph Lakehouse release does not support them.
