Export Geometry and Results
Export geometry and simulation results for use in another application.
Tip: If the other application doesn't convert units automatically, you need to change the unit system in Inspire Form before exporting.
Export Geometry
Export the entire model using the Save As command, or export selected objects using the Save Selected command.
  1. Do one of the following:
    • To export the entire model, select File > Save As.
    • To export only selected objects, first select the objects, and then select File > Save Selected.
  2. Choose a folder, enter a file name, and select a file type.
  3. Click Save.
