SimLab Tutorial Summary: ES3D Streamer in an Insulator
The studied device is an insulator separating two conductors, one at high potential, and another one grounded. The device is in the air.
The aim is to study ionized canals propagation (Streamers propagation) with "Streamer Criterion" Load.
Analysis 1: Streamers propagation
- Global computation: all ionized canals which can propagate from the selected surface and for the project potentials difference, are displayed. The Streamer having the highest probability to propagate and possibly leading to a breakdown (minimal Streamer inception voltage) is displayed in red. The computation results (numerical values and curves) correspond to this Streamer.
- Local computation: the Streamer going from the selected point is displayed. The results including the Streamer inception voltage are created
Example access
All files corresponding to this example are accessible in the following link: Tutorial package.
Example: After installing the SimLab 2025 release, you can find the latest Tuto_2024.zip package. This means that the tutorial has not been updated since 2024 release, that the tutorial does not need to be updated, and that the tutorial still works in 2024.1 release and 2025 release.
Step to follow:
- to follow the example step by step, the corresponding files are in
"Example_name_StepByStep" folder containing:
- Input folder: contains initial *.slb databases an other files needed to be able to play manually the tutorial by following the step by step document
- Output folder: empty (contains the obtained results after to play the tutorial)
- Tutorial folder: contains the document describing the example step by step
- to play the tutorial by scripts, the corresponding files are in
"Example_name_PlayScripts" folder containing:
- Input folder: contains initial *.slb databases an other files needed to be able to run scripts of the tutorial
- Output folder: empty (contains the obtained results after to play scripts of the tutorial)
- ScriptsTutorial folder: contains script files to be able to play each analysis
