SimLab Tutorial Summary: MT2D IPM Motor Brushless
This tutorial shows how to use SimLab to run electromagnetic analysis with Flux solver for electric motors. The studied device, a brushless AC embedded permanent magnet motor, includes the following elements:
- a fixed part (stator) including yoke, slots, and windings
- an air gap
- a movable part (rotor) with surfaced magnets
In this tutorial, four typical transient magnetic analyses are defined to evaluate the motor performance:
- Analysis 1: Computation of the cogging torque
- Analysis 2: Electromotive force
- Analysis 3: Simulation of motor performances (constant speed)
- Analysis 4: Dynamic behavior of the motor (starting)
The cogging torque is computed with a multi-position simulation and no current. The multi-position is simulated with a transient application at constant speed. The speed is chosen to be 1/6 rpm which corresponds to 1 mechanical degree per second.
The back electromotive force EMF is computed with the speed of 1000 rpm and external circuit connections. It corresponds to the motor being in generator mode at no load. The computed back EMF allows determining the current control angle.
The motor is driven with a 3 phase sine current and running at constant speed. The simulated motor performances are used to compute shaft torque.
The dynamic behavior of the motor starting is simulated with a proposed current control strategy. The winding is supplied in current depending on the rotor position.
Example access
All files corresponding to this example are accessible in the following link: Tutorial package.
Example: After installing the SimLab 2025 release, you can find the latest Tuto_2024.zip package. This means that the tutorial has not been updated since 2024 release, that the tutorial does not need to be updated, and that the tutorial still works in 2024.1 release and 2025 release.
Step to follow:
- to follow the example step by step, the corresponding files are in
"Example_name_StepByStep" folder containing:
- Input folder: contains initial *.slb databases an other files needed to be able to play manually the tutorial by following the step by step document
- Output folder: empty (contains the obtained results after to play the tutorial)
- Tutorial folder: contains the document describing the example step by step
- to play the tutorial by scripts, the corresponding files are in
"Example_name_PlayScripts" folder containing:
- Input folder: contains initial *.slb databases an other files needed to be able to run scripts of the tutorial
- Output folder: empty (contains the obtained results after to play scripts of the tutorial)
- ScriptsTutorial folder: contains script files to be able to play each analysis
