FEMT: new interface for Inputs
Introduction
From FeMT 2024.1, the interface of the input "Command mode" has been improved and completed by a new input "Computation mode".
Command Mode (Updated) | Computation Mode (New) |
Updated input: Command mode
- MTPA: Maximum Torque Per Ampere
- MTPV: Maximum Torque Per Volt
The other two command modes MTPA Fast and MTPV Fast have been removed, but new field has been created, entitled Computation mode.
New input: Computation mode
- TM: corresponds to the solving process called
standard in the previous versions, i.e. the former
MTPA and MTPV command
modes.
Solving is performed in Transient Magnetic. This mode allows to compute iron losses and magnet losses.
- MS mono-position: corresponds to the solving process
called fast in the previous versions, i.e. the former MTPA
Fast and MTPV Fast command
modes.
Solving is performed in Magneto Static for a single rotor position. This mode does not allow to compute iron losses nor magnet losses.
Command line
- For the TM computation
mode:
ComputationMode=TM
- For the MS mono-position computation
mode:
ComputationMode=MS_MONO_POS
Comparison before/after 2024.1
Here is the table showing the correspondence between the command modes with versions prior to 2024.1 and the new command and computation modes with version 2024.1:
Before 2024.1 | From 2024.1 | |
Command Mode | Command Mode | Computation Mode |
MTPA | MTPA | TM |
MTPA Fast | MS mono-position | |
MTPV | MTPV | TM |
MTPV Fast | MS mono-position |
