Aller au contenu principal
Documentation Altair® Flux®  2025
2025
  1. Accueil
  2. Quelles nouveautés?
    voici la release notes de la dernière et des précédentes versions, avec les informations nécessaires sur les nouveautés.
  3. Release Notes: Altair® Flux® 2023.1
    Flux 2023.1 is available with new features, corrections and improvements. It is a completely independent version. It is installed by default in its own directory. It can not be installed on top of Flux 2023 (overwrite installation is blocked).
  4. New features of Flux 2023.1
  • Welcome
  • Guide d'utilisation
    Le guide d'utilisation apporte des informations sur les principes et sur comment utiliser Altair® Flux® 2025.
  • Quelles nouveautés?
    • Release Notes: Altair® Flux® 2025
      Flux 2025 is available with new features, corrections and improvements. Flux 2025 is a major release.
    • Release Notes: Altair® Flux® 2024.1
      Flux 2024.1 is available with new features, corrections and improvements. It is a completely independent version. It is installed by default in its own directory. It can not be installed on top of Flux 2024 (overwrite installation is blocked).
      Flux 2024 is available with new features, corrections and improvements. Flux 2024 is a major release.
    • Release Notes: Altair® Flux® 2023.1
      • Essential Information about Flux 2023.1
      • New features of Flux 2023.1
        • List of Flux 2023.1 new features
        • Flux 2023.1: New and Updated Macros
        • FEMT 2023.1: New ribbon with possible functions on a test
        • FEMT 2023.1: Torque Computation Mode
        • Previewing the 3D geometry and creating sensors in Flux Skew before solving
          A new special function for Flux Skew module that enables the pre-visualization of the skewed 3D geometry and the creation of sensors before solving a scenario.
        • Topology optimization in Flux 2D
          The set of structural optimization functions provided in Flux has been improved and expanded in version 2023.1 to include Topology optimization tools for the design of electromagnetic devices.
        • Mechanical problems for free-shape and topology optimization in Flux 2D
          It is now possible in Flux 2D to describe a mechanical problem and account for mechanical responses and constraints in the context of structural optimization.
      • Improvements
      • Fixed Defects
      • About other software – supported version
        Supported versions of software whose coupling is possible with Flux
      • About protection and installation
      Flux 2023 is available with new features, corrections and improvements. Flux 2023 is a major release.
    • Release Notes: Altair® Flux® 2022.3
      Flux 2022.3 is available with new features, corrections and improvements. It is a completely independent version. It is installed by default in its own directory. It can not be installed on top of Flux 2022 and or Flux 2022.1 or Flux 2022.2 (overwrite installation is blocked).
    • Release Notes: Altair® Flux® 2022.2
      Flux 2022.2 is available with new features, corrections and improvements. It is a completely independent version. It is installed by default in its own directory. It can not be installed on top of Flux 2022 and or Flux 2022.1 (overwrite installation is blocked).
    • Release Notes: Altair® Flux® 2022.1.1
      Flux 2022.1.1 is available with corrections and improvements. It should be applied to an existing installation of Flux 2022.1.
      Flux 2022.1 is available with new features, corrections and improvements. It is a completely independent version. It is installed by default in its own directory. It can not be installed on top of Flux 2022 (overwrite installation is blocked).
    • Release Notes: Altair® Flux® 2022.0.1
      Flux 2022.0.1 is available with corrections and improvements. It should be applied as an upgrade to an existing installation of Flux 2022.
      Flux 2022 is available with new features, corrections and improvements. Flux 2022 is a major release.
  • Documents "How to"
    Voici une liste de documents permettant à l'utilisateur de comprendre comment utiliser certaines fonctionnalités.
  • Vidéos Altair Flux
    Plusieurs vidéos youtube sur comment utiliser Altair Flux et plusieurs "trucs et astuces"
  • Superviseur Flux
    Le superviseur de Flux permet notamment de lancer des projets, des exemples, des scripts pythons; de configurer les préférences utilisateur; d'accéder à des outils...
  • Flux
    Flux est un logiciel éléments finis pour les simulations électromagnétiques et thermiques à basse fréquence. Des solutions 2D et 3D sont disponibles.
  • Flux Skew
    Flux Skew est un module dédié à l'analyse des machines électriques tournantes avec vrillage, permettant une description géométrique et physique simple en 2D et la prise en compte des effets du vrillage, continu ou en escaliers.
  • Flux PEEC
    Flux PEEC est un module de simulation 3D pour les dispositifs d'électronique de puissance. Il permet entre autres de calculer les paramètres RLC parasites des connexions électriques.
  • Caractérisation de matériaux
    Flux fournit un outil de Caractérisation de matériaux basé sur l'environnement Compose permettant d'identifier les différents coefficients requis pour la création d'un matériau dans Flux.
  • Altair Material Datacenter (AMDC)
    AMDC est une vaste base de données maintenue par Altair et des fournisseurs de matériaux d'ingénierie partenaires. Des modèles prêts à l'emploi et compatibles avec Flux peuvent être obtenus directement auprès de cette base de données pour un nombre croissant de matériaux.
  • Gestionnaire de matériaux
    Flux dispose d'un gestionnaire de matériaux avec sa propre base de matériaux. L'utilisateur peut créer sa propre base de matériaux et les importer dans un projet Flux.
  • Flux e-Machine Toolbox
    FeMt est une application de Flux dédiée aux machines électriques qui permet de calculer et d’exploiter les résultats comme les cartes de performance.
  • Exemples Flux
    Listes des exemples 2D, 3D, SKEW, PEEC et Flux dans SimLab avec les documents disponibles et les projets et fichiers python.
  • Exemples de Flux dans SimLab
    Listes des exemples SimLab utilisant les solveurs Flux et Mipse, avec les documents les databases *.slb et les scripts disponibles.
  • Mementos
    Voici plusieurs mementos permettant de comprendre certaines fonctionnalités de Flux.
  • Macros
    Flux propose plusieurs macros permettant de réaliser des actions pas encore implémentées sous forme de fonctionnalité dans Flux.
  • Documentation PyFlux (version Beta)
    Cette documentation concerne le script Jython utilisé dans Flux, et permet de comprendre les différentes structures d'entités et de fonctions, et de les réutiliser dans des scripts utilisateur.
  • Guide d'installation de Flux
    Ce document fournit des instructions pour l'installation de Flux sur les systèmes d'exploitation supportés.
  • Flux Starting Guide
    Plusieurs courtes vidéos pour démarrer avec Flux.
Introduction
  • New features with more details:
© 2024 Altair Engineering, Inc. All Rights Reserved.
