Depuis la version 2026, Flux 3D et Flux PEEC ne sont plus disponibles.
Veuillez utiliser SimLab pour créer un nouveau projet 3D ou pour importer un projet Flux 3D existant.
Veuillez utiliser SimLab pour créer un nouveau projet PEEC (pas possible d'importer un projet Flux PEEC existant).
/!\ La documentation est en cours de mise à jour – des références au 3D peuvent subsister.
Previewing the 3D geometry and creating sensors in Flux Skew before solving
A new special function for Flux Skew module that enables the pre-visualization of the skewed 3D geometry and the creation of sensors before solving a scenario.
Introduction
- Verify that the 3D skewed geometry generated by the extrusion performed by Flux Skew and the corresponding physical description are correct.
- Create sensors before solving the actual users' scenarios. In Flux Skew, this procedure allows a faster evaluation of the sensors when compared with evaluating sensors created after solving.
Where to find this special function
In Flux Skew module and for all applications while in pre-processing the Create preview 3D command can be accessed through the Solving menu as depicted in Figure 1.
At a second step a pop up window prompts for a project name (Figure 2). The user may choose a new name for that project or overwrite it by providing the current project name.
At this point, Flux Skew will build a scenario called PREVIEW3D, which becomes automatically active (Figure 3). The user can then explore the skewed design in 3D and eventually create sensors.
Allowed post-processing actions within the PREVIEW3D scenario
The most important actions that are allowed in the PREVIEW3D scenario are summarized in Table 1 below. The availability of the same actions in the regular 2D context of Flux Skew (before solving) and in a proper scenario (after solving) are also shown in that table, for the sake of comparison.
| Context in Flux Skew | |||
| Possible actions | 2D view (before solving) | PREVIEW3D scenario | Regular solved scenario |
| Create sensors |
| Change 2D geometry and physics | |||
| Check skewed geometry | |||
| Create new scenario | |||
Transitioning between the pre-processing (2D view), preview 3D and post-processing contexts (Regular solved scenario) of a project in Flux Skew
Figure 4 below illustrates the different states of a Flux Skew project and the actions required to transit between them.
