Depuis la version 2026, Flux 3D et Flux PEEC ne sont plus disponibles.
Veuillez utiliser SimLab pour créer un nouveau projet 3D ou pour importer un projet Flux 3D existant.
Veuillez utiliser SimLab pour créer un nouveau projet PEEC (pas possible d'importer un projet Flux PEEC existant).
/!\ La documentation est en cours de mise à jour – des références au 3D peuvent subsister.
Java Library Refactoring
With Flux 2022.2, CedUtils and FactoryTools have been refactored.
CedUtils refactoring
The import of Java classes from CedUtils has been modified.
A Java package level has been added, it is named cedUtils.
Therefore in the Python scripts, the following line:
from tools import SystemHelper
will now be:
from cedUtils.tools import SystemHelper
This is valid for all imports from CedUtils and thus concerns the modules:
| With previous Flux versions | With Flux 2022.2 |
| application | cedUtils.application |
| collection | cedUtils.collection |
| com.* | cedUtils.com.* |
| configuration | cedUtils.configuration |
| formater | cedUtils.formater |
| internationalization | cedUtils.internationalization |
| io | cedUtils.io |
| logging | cedUtils.logging |
| model | cedUtils.model |
| network | cedUtils.network |
| process | cedUtils.process |
| properties | cedUtils.properties |
| swing | cedUtils.swing |
| tools | cedUtils.tools |
| xml | cedUtils.xml |
FactoryTools refactoring
Several modules have been moved into a new package named jutils:
| algo | jutils.algo |
| collection | jutils.collection |
| configuration | jutils.configuration |
| iotools | jutils.iotools |
| local | jutils.local |
| preference | jutils.preference |
| properties | jutils.properties |
| stp | jutils.stp |
| swing | jutils.swing |
| tools | jutils.tools |
| viewtools | jutils.viewtools |
