Depuis la version 2026, Flux 3D et Flux PEEC ne sont plus disponibles.
Veuillez utiliser SimLab pour créer un nouveau projet 3D ou pour importer un projet Flux 3D existant.
Veuillez utiliser SimLab pour créer un nouveau projet PEEC (pas possible d'importer un projet Flux PEEC existant).
/!\ La documentation est en cours de mise à jour – des références au 3D peuvent subsister.
About external software – supported version
Supported versions of software whose coupling is possible with Flux
External softwares
The use of external softwares can be achieved with the versions listed in the table below.
| External software | Supported version | Supported OS |
| Simulink | 2020 a&b, 2021 a&b | Windows |
| Matlab | 2020 a&b, 2021 a&b | Windows / Linux |
Altair softwares
The coupling between Flux 2022 and other Altair softwares can be achieved with these versions:
| Functionalities | Altair software | supported version (and above) | Windows 10 | Linux (RHEL 8 and SUSE 15.1) |
| Export to .. (Vibroacoustics and mechanical analysis) | OptiStruct | 2022 | ||
| Export to.. (Thermal analysis) | AcuSolve | 2022 | ||
| Co-simulation | Activate | 2022 | ||
| Co-simulation | Compose | 2022 | OML language: Python language: |
| Mesh import | HyperMesh | 2022 | ||
| Mesh import | SimLab | 2022 | ||
| Optimization | HyperStudy | 2022 |
ACIS - InterOp : Format and Version Supported
Flux 2022 is compatible with ACIS 2019 1.0.1 version.
| Format | Extension | Supported version by ACIS 2017 1.0 |
| ACIS | .sat, .sab, .asat, .asab | R1 – 2019 1.0 |
| CATIA V5 | .CATPart, .CATProduct | V5R8 – V5–6R2019 |
| DXF | .dxf | 2.5 - 2019 |
| IGES | .igs, .iges | Up to 5.3 |
| Inventor | .ipt (V6 – V2017) | V11 – 2019 |
| NX | .prt | 11 – NX 12.0.0 |
| Parasolid | .x_t, .xmt_txt, .x_b, .xmt_bin | 9.0 – 31.1.188 |
| Pro/E /Creo | .prt, .prt.*, .asm, .asm.* | 16 – Creo 5.0 |
| SolidWorks | .sldprt, .sldasm | 98 – 2019 |
| STEP | .stp, .step | AP203, AP214, AP242 |
| Format | Extension | Versions Supported by ACIS 2017 1.0 |
| ACIS | .sat | R18 – 2019 1.0 |
| CATIA V5 | .CATPart, .CATProduct | V5 R15 – V5–6 R2019 |
| IGES | .igs, .iges | 5.3 |
| STEP | .stp, .step | AP203, AP214, AP242 (Geometry only) |
