Depuis la version 2026, Flux 3D et Flux PEEC ne sont plus disponibles.
Veuillez utiliser SimLab pour créer un nouveau projet 3D ou pour importer un projet Flux 3D existant.
Veuillez utiliser SimLab pour créer un nouveau projet PEEC (pas possible d'importer un projet Flux PEEC existant).
/!\ La documentation est en cours de mise à jour – des références au 3D peuvent subsister.
Non-connected volume regions of type "coil conductor region" in Flux 3D
Overview
The new possibility is not available with the “Analytical method or by interpolation from lines“, only with “Method with electric conduction resolution + uniform J norm” to compute the current density J in these regions (available from the Solving menu, with the following choices: Solving process options > Edit > Advanced tab). For the moment, a Coil conductor region with losses and detailed geometrical description, always uses the Analytical method or by interpolation from lines.
Orienting coil conductor regions
- Orient wires of coil conductor region (completion mode), and
- Orient wires of coil conductor region (modify mode).
