Altair Flux Videos
Introduction
Several Youtube videos about how to use Altair Flux and several tip and tricks have been done by Support teams. All links has been added directly in the help documentation.
- Local Help : [Install Dir]+/flux/Flux/Help/english/UserGuide/English/topics/fluxvideos.htm
- Online Help: https://help.altair.com/flux/Flux/Help/english/UserGuide/English/topics/fluxvideos.htm
"How to" videos
- How to create a simple 2D project in Flux?
- Axial Flux Machine - From input to results using macros
- Demagnetization Effect on the Permanent Magnet Machine using Flux 2D/3D
- Rotor Eccentricity Modeling
- 3D modeling in Flux - Meshing and Cogging torque computation
- Iron losses computation with Flux
- How to obtain radial skew spatial magnetization
- How to set up Steady-state AC Magnetic coupled with Transient Thermal application
- How to include iron losses in Steady state AC Magnetic coupled with Transient Thermal application
- Efficiency map computation using Flux and FluxMotor
- Magneto Mechanical Topology optimization
- Magneto Mechanical Shape Optimization
- Export reduced order model of Synchronous Motor in Flux and FluxMotor
- Flux/FluxMotor -PSIM coupling for system simulation
- Considering Mechanical stress in B(H) curve of laminations
- Inductance computation
"Tip and Tricks" videos
- How to orient Magnets
- How to import 2D geometry from 3D
- How to check if the mesh is periodic
- How to get Python command of an entity
- How to determine initial position of Rotor
- How to consider Dynamic eccentricity for rotating machine
- How to determine control angle for PMSM
- How to determine Stall torque
- How to determine Torque constant
- How to setup Hyperstudy-Flux Connections
- How to setup layer mesh generation
- How to switch from current sources to voltage source for PMSM motor
- How to create Non -meshed coils
- Tips to solve faster in Altair Flux
