Composed Non Meshed Coil by File Import
Introduction
To be able to create a composed non meshed coil with a lot of points and avoid to have limitation in the execution of python containing too much lines, a new type of non meshed coil has been added and called Composed coil by file import.
This new type of composed coil will be powerful:
- For Flux users, to be able to create non meshed coil without restriction on the number of definition points.
- And indirectly also by SimLab users. In SimLab, it is possible to generate a file with a list of points of the neutral fiber of a body, and then use this file to create an non-meshed coil in SimLab equivalent to this new type of composed non meshed coil in Flux.
Composed Coil by file import
A dedicated type is available to create a composed non meshed coil directly by importing a csv file.
| The CSV should be formatted as below | |
Difference between 2 possibilities of creation by import
It exists 2 possibilities of creation of composed non meshed coil by import:
- By using the Composed coil type + using the
"Import" button to fill the table with points
informations, contained in a txt file (already existing).Tip: Recommended for few points
- By using the Composed coil by file import type, with
directly a selection of csv file, without table in the dialog box (added in
this release 2024.1).Tip: No limit of number of points. It's recommended when a lot of points are required.
| Difference between the both possibilities of creation of non mesh coil by import | |
| Composed coil + "Import" button | Composed coil by file import |
Fill the table in the dialog box![]() |
No table in the dialog box![]() |
Limited number of points, because there is a limitation on the number of lines of a script python when it is executed. |
No limitation of the number of points, because the python command contains only the csv file, not all the coordinates of each point. |
| The corresponding python contains the list of point with X,Y,Z coordinates and the curvature radius.* | The corresponding python contains only the csv file.** |
Python Examples
- *Composed coil type
ComposedCoil(name='COIL_2', strandedCoil=CoilConductor['COILCONDUCTOR_1'], turnNumber='1', seriesOrParallel=AllInSeries(), coilDuplicationBySymmetriesPeriodicities=CoilDuplication(), coordSys=CoordSys['XYZ1'], coilPath=ClosedPathCoil(coilPoints=[CoilPoint(coordinates=['0', '0', '0'], radius='0'), CoilPoint(coordinates=['0', '10', '20'], radius='0'), CoilPoint(coordinates=['0', '10', '30'], radius='0'), section=PointCoilSection(sectionRadius='1'), color=Color['Turquoise'], visibility=Visibility['VISIBLE']) - **Composed coil by file import type
ComposedCoilByFile(name='Coil_1', strandedCoil=CoilConductor['COILCONDUCTOR_1'], turnNumber='1', seriesOrParallel=AllInSeries(), coilDuplicationBySymmetriesPeriodicities=CoilDuplication(), coordSys=CoordSys['COIL_COORDSYS'], coilPath=OpenPathCoilByFile(file='import_FX34525.csv'), section=DiscCoilSection(sectionRadius='1'), color=Color['Turquoise'], visibility=Visibility['VISIBLE'])
