- Line
Create a line to be used either as a building block for constructing or modifying geometry or as a wire.
- Polyline
Create a polyline to be used either as a building block for constructing geometry or as a wire.
- Fitted Spline
Create a fitted spline to be used either as a building block for constructing geometry or as a wire. The fitted spline fits a smooth curve through all the node points in the definition.
- Analytical Curve
Create an analytical curve to be used either as a building block for constructing geometry or as a wire. Analytical curves are parametric definitions (in the parameter t
) that define the path in three coordinate systems.
- Bézier Curve
Create a Bézier curve to be used either as a building block for constructing geometry or as a wire.
- Parabolic Arc
Create a parabolic arc to be used either a building block for constructing geometry or as free-standing wires.
- Hyperbolic Arc
Create a hyperbolic arc to be used either as a building block for constructing geometry or as a wire.
- Elliptic Arc
Create an elliptic arc to be used either as a building block for constructing geometry or as a wire.
- Helix
Create a helix to be used either as a building block for constructing geometry or as a wire.
