Homogeneous Medium
With this option the dielectric properties for the entire problem space can be set. This is useful for modelling in a homogeneous medium that differs from free space.
free spaceGreen’s function similar to when the GF card is not used. The medium is normally free space, defined by material label
0, but different parameters can be set with the DI card.
Parameters:
- Material label
- The label of the homogeneous medium to be used, as defined in the DI card
