Non-Conducting Element
This option defines a non-conducting fibre used as spacing elements and for additional strength to cables.
Figure 1. The CD - Cable cross section definition dialog.
Parameters:
Cross section label
The label of the cross section.
Material label
The label of the dielectric (as defined in the DI card) to be used for the non-conducting fibre.
Radius
The radius of the non-conducting fibre.
Cable per-unit-length parameters accuracy
The Cable per-unit-length parameters accuracy can be increased from Normal (default) to High or Very high.
