Create Coaxial Feed Macro
The Create Coaxial Connector Feed application macro creates a coaxial connector on a finite substrate.
This application macro uses three defined named points in the model to define where the coaxial connector will be located. The coaxial connector is defined using an outer diameter, inner diameter, coaxial length and insulating dielectric.
